Will I Have To Replace The Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 11:24 AM   #1
Will I have to replace the panel?
I was planning to add a circuit for a heater in my garage. The box is a Sylvania (c. 1980). It seems they don't make this breaker any more. The guy at the big box store said the only fix is to replace the whole circuit breaker panel. I've decided to postpone adding the circuit; but although I don't have any problems now, if a breaker ever fails will I need a whole new box, or is there an alternative?
Pistol Pete is offline   Reply With Quote
Old 10-04-2010, 01:25 PM   #2
Licensed electrician
Rewards Points: 1,272
Just google obsolete breaker suppliers. You should be able to find someone with the breaker you need.
Old 10-04-2010, 01:59 PM   #3
Been there, done that, didn't find any.
Old 10-04-2010, 04:05 PM   #4
sylvania = commander
breakers are still made, just installed a couple myself (brand new)
try a real electrical supplier rather than Big Orange
CuHead is offline   Reply With Quote
Old 10-04-2010, 04:57 PM   #5
Electrical Contractor
kbsparky's Avatar
OR, you could install some "classified" breakers in that panel. I believe that Cutler-Hammer type CL breakers are available and are classified for use in most interchangeable panels.
-KB
OSB Panel Siding: Repair or Replace SirDieAlot Building & Construction 5 06-03-2008 09:19 AM
Replace a service panel circuit breaker knockout? michigan_homeowner_2008 Electrical 6 05-22-2008 05:01 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 01:20 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
