Will I Get Electrocuted If I... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 07:47 PM   #1
Question Asker
Send a message via AIM to xamplesample
Unhappy
snip a wire using rubber handled needle nose?
xamplesample is offline   Reply With Quote
Old 01-18-2009, 07:54 PM   #2
DIYer
You will likely damage your cutters. If you snip a cable, there will be fireworks. If you snip a wire, depending on how many amps are going through it, you may still damage your cutters. It's not a good idea.
Gigs is offline   Reply With Quote
Old 01-18-2009, 07:57 PM   #3
Question Asker
even if the light switch is off in that room, and it's the light fixture i'm snipping?
Old 01-18-2009, 08:03 PM   #4
Its possible to damage it with the switch off...why are you working with the breaker ON?!?
rgsgww is offline   Reply With Quote
Old 01-18-2009, 08:47 PM   #5
Licensed electrician
Rewards Points: 1,030
There is no reason for a DIY to be working hot. There are very few reasons for someone with proper training and protective gear to work hot.
Old 01-18-2009, 08:53 PM   #6
Rewards Points: 820
You want to work hot why? Because you don't want to shut off the lights in the room, or inconvenience someone else in the house?
Think about this. Is it worth the possibility of shocking yourself, or worse?
Falling off the ladder you are standing on?
Working live is just not worth the risk. Just cut power and do the work safely!
FW
Ultrarunner2017 is offline   Reply With Quote
Old 01-18-2009, 09:01 PM   #7
Registered User
Termite's Avatar
Some things are such a bad idea that the answer to the question is not even worth discussing or debating. The answer to the question is maybe you'll get electrocuted, and cutting the wire on a live circuit is a completely unsafe and unwise idea. If the circuit is definately shut off and dead, you're ok to cut. There is absolutely no reason or excuse to cut a wire or work on any wire in a home with the breaker still on, so be sure that breaker is off.
If you have to ask the question it would be worth taking a hard look at what you're doing, why you're doing it, and whether or not you have the know-how to do it safely and successfully.
All good answers to the question thus far.
Old 01-18-2009, 09:37 PM   #8
Registered User
Termite's Avatar
I initially closed this thread and have reconsidered when asked to do so. However, it is on a short leash. We must advocate for safety on this site and can't even consider discussion on the merits of working on a hot circuit.
Old 01-18-2009, 10:08 PM   #9
Licensed Pro
The OP is asking if it is OK to cut the wires to a light fixture with just the switch off. A properly wired light fixture should be safe to be disconnected if the switch is off. This is not the ideal way, and for a DIYer, is not the recommended way, and that should be pointed out, but you will not be electrocuted in doing so.
Just be aware there may be other wires in the fixture box that remain hot.
Old 01-18-2009, 11:16 PM   #10
Idiot Emeritus
Rewards Points: 1,492
Even if you can safely cut the wires while hot, at some point you'll need to strip them in order to install a new fixture. This is nearly impossible to do without coming in contact with the copper part of the wire.
Rob
micromind is offline   Reply With Quote
Old 01-19-2009, 12:00 AM   #11
Although you are correct, you should cut to the chase.
It is possible that the circuit is not wired correctly and yes, you could get electrocuted.
joey b is offline   Reply With Quote
Old 01-19-2009, 12:16 AM   #12
Breaker off and switch off the rubber handle is still good. It does not replace having the power off. But can ou allways be sure the power is off?? However there are special tools made for live circuits. And they go with experience and the need for the circuit to be left on when needing service. I can't see this being the case for ANY home DIY. So don't expect a tool to protect you from you lack of respect or ignorance. If the question is actually asked then there is not enough experience yet and should not be done! However the rubber is still good I think anyone that has worked long enough with electricity (unless they shut down the main every time) has found a circuit live that they expected to be dead. It was shut down and the switch was off. Maybe mislabeled maybe back feeding. A test light can be a friend indeed. If cutting into a wire on or off it is good to have a insulator between you and the tool. Then test the edge to ground before trying to strip so you are for sure it's NOT live.
I can't say I always do this and I will also say it's NOT a good to idea to work on a aluminum ladder bare foot.
Mgmopar
MgMopar is offline   Reply With Quote
Old 01-19-2009, 01:36 AM   #13
Tom Struble's Avatar
Rewards Points: 2,002
back feed will get you belive me i learned that the hard way if you dont know shut the main
Tom Struble is offline   Reply With Quote
Old 01-19-2009, 08:01 AM   #14
I want everyone to know that they don't put the rubber on there to "protect" you. Its just for comfort.
Old 01-19-2009, 11:21 AM   #15
Registered User
Termite's Avatar
Copper can expand up to 67,000 times its original size in an arc flash when it goes from a solid to a plasma. Think about that! That can result in burns, shocks, and shock wave injury such as collapsed chest/organs (on larger arc flash explosions).
Could have been electrocuted? What was I thinking? fallontheball Electrical 14 11-09-2008 05:30 PM
