Will Halogen Lamp Work In Metal Halide Fixture? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 09:17 PM   #1
Will halogen lamp work in metal halide fixture?
Hello, I have some metal halide fixtures in my store that say on it to use a Par30 m130/0 lamp. I have priced out these lamps and they are pretty pricey. I am being told that a halogen lamp will work in these fixtures. Is that true or are they full of it?
Thank you
bobby5858 is offline   Reply With Quote
Old 07-18-2012, 09:24 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Full of it
Old 07-18-2012, 09:31 PM   #3
Electrical Contractor
kbsparky's Avatar
One might be able to retrofit a fixture by bypassing the ballast, but that would be labor intensive ...
-KB
Old 07-18-2012, 09:36 PM   #4
not retrofitting but just the changing to a halogen lamp. I will tell them they are full of it but not looking forward to the price tag with all the lights.
Old 07-18-2012, 11:11 PM   #5
Rewards Points: 1,418
No you may not simply substitute a tungsten halogen (a kind of incandescent) lamp for a metal halide lamp (a kind of mercury lamp) even if it fits in the socket.
It is possible that some halogen lamps may work with some halide ballasts left in place but I don't know what combinations work and the wrong combination could overheat the ballast.
Furthermore, halogen lamps give off much more heat than halide lamps for a given wattage, so if you did bypass the ballast and put in a halogen lamp, you should substitute a lamp of no more than half the wattage to avoid overheating the fixture and possibly causing a fire hazard. (Halogen lamps don't need ballasts.)
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 02:33 PM
isolating noise transmission in metal duct work BrandonHook HVAC 2 12-07-2008 07:37 AM
halogen desk lamp Banker 21 Lamp bh4bhwgm Electrical 3 09-29-2008 05:55 AM
Metal halide lamp Richo Electrical 13 01-20-2008 03:37 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
