Will This GFCI Outlet Setup Work - Electrical - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 09:37 PM   #1
Rewards Points: 242
will this GFCI outlet setup work
Currently I have a duplex outlet that is controlled by a wall switch.
There is 12-2 bringing power in then 12-2 to a switch. The switch is several feet away if that matters. I want to add a GFCI outlet several feet away that is always on. I do not want the GFCI controlled by the switch.
Will the way I have the GFCI added in work? Or will this way keep tripping the GFCI everytime I flip the switch for the normal duplex?
collegetry is offline   Reply With Quote
Old 10-15-2012, 09:49 PM   #2
Resi EC
Rewards Points: 252
Looks good from this angle.
Gac66610 is offline   Reply With Quote
Old 10-16-2012, 12:41 AM   #3
" Euro " electrician
frenchelectrican's Avatar
It look good however the question is where is being used in ?
Living room or what ?
Merci,
Marc
Old 10-16-2012, 09:43 AM   #4
Rewards Points: 242
An attached garage.
Old 10-16-2012, 09:49 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
All garage recepts need to be GFI protected.
Outlet Inside Vanity Cabinet - Does It Need To Be GFCI? LowlyDIYer Electrical 18 02-05-2012 09:41 AM
10 amp Vacuum popping GFCI Outlet brgmgb Electrical 19 12-29-2011 11:45 PM
Porch outlet, and livingroom on bathroom GFCI circuit? Is that uncommon? 211 Electrical 5 01-06-2011 03:13 PM
cant figure out why the outlet wont work jamjar Electrical 6 09-16-2009 03:17 PM
Problems with GFCI Outlet FieldersChoice Electrical 11 01-04-2009 02:53 PM
