Will This GFCI Method Work - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 07:10 PM   #1
Rewards Points: 242
will this GFCI method work
Will this kind of shared neutral for the line-load side of the GFCI work? Basically I want to run 12-2 from breaker to a junction box. Then run a 12-3 to a separate location with the GFCI using the red on the 12-3 for protecting downstream load outlets. Not sure about the same neutral being shared from the 12-3??? See drawing
collegetry is offline   Reply With Quote
Old 10-13-2012, 07:18 PM   #2
Rewards Points: 13,968
Why a juntion box and not just run the wires to the reguler outlet , add a line to the GFI line side then run the load side to whatever it is your trying to protect.
The way you drew it makes no since doing it that way to me.
Old 10-13-2012, 07:21 PM   #3
Electrician
Rewards Points: 150
Won't work. Can't share neutral.
Glennsparky is offline   Reply With Quote
Old 10-13-2012, 07:23 PM   #4
Bingo, Did you read my suggestion Glenn?
Old 10-13-2012, 07:24 PM   #5
Rewards Points: 242
Originally Posted by joecaption View Post
Why a juntion box and not just run the wires to the reguler outlet.
Because the 12-2 from the panel will be run to the junction box first. I understand that the ideal way is to run the 12-2 from the panel to the box with the GFCI without a junction box but that wasnt my question.
Old 10-13-2012, 07:25 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 536
The way it is drawn will not work.
What are you trying to do?
Old 10-13-2012, 07:26 PM   #7
Electrician
That will not work. The line & load neutrals need to be separate. The GFCI outlet works by measuring the current on the hot & neutral, and if there is a difference it will trip. By wiring it that way, the neutral from the second outlet will bypass the gfci, and trip it as soon as you plug anything in to it.
You will have to run 2 12-2's from the jb to the gfci.
dawizman is offline   Reply With Quote
Old 10-13-2012, 07:27 PM   #8
Rewards Points: 242
Trying to eliminate having 2 two 12-2 cables at the GFCI location. One 12-2 bringing the line in and one 12-2 taking the load out to a nornal duplex. But if the 12-3 will not work I have no choice
Old 10-13-2012, 07:28 PM   #9
Rewards Points: 242
Originally Posted by dawizman View Post
that will not work. The line & load neutrals need to be separate. The gfci outlet works by measuring the current on the hot & neutral, and if there is a difference it will trip. By wiring it that way, the neutral from the second outlet will bypass the gfci, and trip it as soon as you plug anything in to it.
good explanation. Case closed. Thanks to all
GFCI special application--on demand for brief period highdeserthome Electrical 33 01-20-2012 11:19 AM
GFCI troubleshooting XwpisONOMA Electrical 20 11-13-2011 05:19 PM
GFCI circuit resets but does not work Alexlonebear Electrical 2 12-15-2010 09:20 AM
GFCI Issues SilentPete Electrical 6 10-07-2010 05:09 PM
GFCI between porch receptacles Thurman Electrical 4 08-19-2009 12:40 PM
