Will This Be Fine??? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 04:49 PM   #1
Will this be fine???
Im new here, Great forum!!
But heres my question. I was told it should fine, but i figured i should see what you guys say about it. In order to run a 230v welder in my garage I have to plug into my dryer plug. I have to make a 25ft extension cord from the dryer plug to my welder. The amp draw for the welder will be no more then 34amps. My extension cord will be a 25ft. 8/3 copper extenstion cord. My dryer plug is about 35ft from the fuse box and the wire running to it is alcoa 600v 6 guage, it is aluimum wire. The breaker for my dryer plug is a 50amp. Would everything work out alright or will i have issues? My main concern is the 6ga alu wire on a 50amp breaker, but i would be only drawing no more then 34 amps. Thanks
suzukishane is offline   Reply With Quote
Old 11-02-2010, 06:27 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
If it is #6 al, it can not be on a larger breaker than 40, and since it is a dryer, it should be on a 30.
Your plan will not work.
jbfan is online now   Reply With Quote
Old 11-02-2010, 07:10 PM   #3
Thanks jp,
It is #6 alu. Is #6 alu even safe with a 50 amp breaker?
No hot water pressure in up stairs shower. Cold is fine. my4boyz27 Plumbing 1 09-09-2010 04:31 PM
Washing Machine Overflowing Suddenly After Working Fine For Months tonywolfe Plumbing 5 08-01-2010 02:34 PM
2x6 insulation in 2x4 walls.. Bad idea or just fine? slowjo Building & Construction 14 06-10-2009 10:00 AM
Fine thread to Coarse thread??? tlavery Plumbing 11 04-13-2009 09:51 PM
Fine White Fiberous Dust Murpet General DIY Discussions 6 03-28-2005 02:27 PM
