Will Code Allow It Done This Way? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2009, 08:03 PM   #1
will code allow it done this way?
Fishing/ running a single ground wire in the wall to each outlet then back to the main panel bus bar for a proper equipment ground, so as to now have a 3 wire outlet instead of two.(12 outlets total to ground) This code would apply to the state of Florida.
thanks to all electricians and diy'ers
tech526 is offline   Reply With Quote
Old 02-24-2009, 08:10 PM   #2
Rewards Points: 150
Send a message via AIM to Bocolo
I am not sure it will be legal it probably would but if you are going to fish and run wire anyway why not just fish and run 12/2 with a ground and have new wire for the same amount of work? Just my opinion. Thanks.
Bocolo is offline   Reply With Quote
Old 02-24-2009, 08:11 PM   #3
Rewards Points: 150
Wait a minute I was going to say that!
Gary
Gary_602z is offline   Reply With Quote
Old 02-24-2009, 08:13 PM   #4
It's a lot less $$ to run 1 wire, still a PIA
I ripped out the only 2 wire run I had & replaced it
I've also replaced almost all of the wire from the 50's in my house
Old 02-24-2009, 08:15 PM   #5
Rewards Points: 150
Gary
Extra Sensory Perception from being shocked once.
Old 02-24-2009, 08:28 PM   #6
Rewards Points: 150
Wait a minute I resemble that remark!
Gary
Old 02-24-2009, 09:21 PM   #7
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Snip snip snip bye bye old wire.
Run new romex. Copper is cheap.
Do it right and just run 12-2 with ground. I hate cobble jobs.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
code details for boxes kama Electrical 6 01-30-2009 10:25 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
NEC 2008 Code Cycle jamiedolan Electrical 19 10-05-2008 06:42 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
