Will This Box Use Tandems Or Can I Just Replace? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2009, 12:32 PM   #1
will this box use tandems or can I just replace?
will this box work with tandem breakers the cover says cuttler hammer br1020b100gk there is a 100 amp main. I would like to add a range but don't have enough room on the breaker for two slots for it. Form what I am reading in the search I may be able to just replace the box as long as I don't exceed the amerpage. I won't be doing the work but want to know what needs to be done before I call someone. If i didnt have to add a subpanel I don't want to otherwise I would just get a new stove. Any thoughts
shoguntalon is offline   Reply With Quote
Old 10-25-2009, 12:36 PM   #2
Electrical Contractor
kbsparky's Avatar
From the model number posted, it would appear that you have a 10 space panel, with 20 maximum number of allowable circuits.
Tandem breakers should work fine in such a panel.
Care to post a pic of your panel?
-KB
Old 10-25-2009, 08:59 PM   #3
box pic
[IMG]file:///F:/DCIM/103_PANA/P1030254.JPG[/IMG]here is the box
Old 10-25-2009, 09:46 PM   #4
kbsparky's Avatar
You already have a boxload of tandems there. It would appear that you will have to install a couple of "Quad" type breakers in place of those 30 Amp double poles to free up the required spaces for your 50 Amp circuit.
-KB
Old 10-25-2009, 11:37 PM   #5
I don't think there is one Cutler Hammer breaker in the panel
I hate twin breakers but they will fit. The 10/20 number indicates 10 full size or 20 twins. a 30/40 quad might be the easiect way to squeeze in the range circuit. Those single pole 30's (green) also look suspect. If those are 120V circuits, they are probably 12 or 14 wire and should be on 15 or 20's. If you need to change those you could twin them up and move the 15 and 20 over (blue and red) to make room for a full sized 40 for the range.
220/221 is offline   Reply With Quote
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 08:39 AM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
