Will 20Amp Service Work Here - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2007, 11:31 AM   #1
I have a recently built home, with a dedicated 20 Amp outlet in the laundry room for the washer (The Dryer is on another outlet).
I want to add a small chest freezer in the room. The plates on the 2 appliances state:
Washer - 120v 60Hz 10Amp
Freezer 115v 60Hz 1.7Amp 1 Phase
Will this 20 Amp Outlet handle both of them? By simple math it looks like it will, am i missing something? I am rookie with electrical work.
ImproveInVA is offline   Reply With Quote
Old 02-11-2007, 11:42 AM   #2
jproffer's Avatar
Rewards Points: 702
Small Freezer? 1.7A at 115V?
Unless your local code says you MUST have a dedicated circuit for either of these appliances, one 20A circuit will handle both.
jproffer is offline   Reply With Quote
Old 02-11-2007, 11:47 AM   #3
It's a GE 7 Cu Ft chest freezer. The tag on the back says Rated Current 1.7A and 115v. I really am a rookie, so I am not sure what you meant by "Small Freezer? 1.7A at 115V?"
Or if you were just saying it is small, so no worries.
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
Service upgrade rondo Electrical 1 05-21-2007 07:19 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
