Will A 208v Motor Run On 240v Power? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 11:29 PM   #1
will a 208v motor run on 240v power?
rodorjenn is offline   Reply With Quote
Old 03-12-2011, 11:49 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
sure
now, do you want to know if it will hurt it?
maybe.
The highest voltage you should put to a 208 volt motor is 228 volts. That's the +10% NEMA requires equipment to be able to withstand.
The Following 2 Users Say Thank You to nap For This Useful Post:
J. V. (03-13-2011), rodorjenn (03-13-2011)
Old 03-13-2011, 04:11 AM   #3
" Euro " electrician
frenchelectrican's Avatar
It may able do so but the main item is read the motour nameplate that will tell you the voltage requriement if you are on the low side of 240 volt range that will useally not a issue but if you are on high side of 240 volt range then may have some issue.
Again just double check the nameplate on the motour to verify it.
If say 208-240 volts then it is not a issue at all.
Merci.
Marc
Old 03-13-2011, 07:59 AM   #4
Rewards Points: 1,512
Be sure it is not a three phase motor, that is, does not require three supply wires to feed it..
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 09:43 AM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
