Wiering 220V 20 Amp Straight Blade Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-13-2014, 01:20 PM   #16
Rewards Points: 3,256
Originally Posted by giser3546 View Post
And my regular 12/2 wire will do the job?
For a 20 amp circuit, yes.
zappa is offline   Reply With Quote
Old 06-13-2014, 01:39 PM   #17
Rewards Points: 45
The plug does not look significantly larger than a regular 110 VAC outlet. Would that mean I need the outlet I first mentioned?
giser3546 is offline   Reply With Quote
Old 06-13-2014, 01:45 PM   #18
See post #15
Old 06-13-2014, 01:49 PM   #19
Rewards Points: 45
Yes but I was previously told not to use the 20 amp outlet...
http://www.lowes.com/pd_70708-334-18...3D2&facetInfo=
, per the earlier posts.
Old 06-13-2014, 01:51 PM   #20
I'm sorry, I didn't see that. In this thread? Which post?
Old 06-13-2014, 01:58 PM   #21
Rewards Points: 45
It was edited in correction, apparently it was mistaken for a 120 VAC outlet. That will be the one I go with, using my 12/2 wire. Although I'm not 100% on how I would hook it to my breaking without the - wire.
Old 06-13-2014, 01:59 PM   #22
Rewards Points: 45
... breaker... not breaking.
Old 06-13-2014, 02:24 PM   #23
Rewards Points: 3,396
not sure but is the horse going before the cart?
Wiring the circuit based on wire and receptacle?
What does the name plate on the machine say?
volts,amps,hp?
Is there anything on that motor that say's thermally protected, or tp?
How is the motor controlled?
Are your socks too loose?
ritelec is offline   Reply With Quote
Old 06-13-2014, 02:26 PM   #24
Rewards Points: 366
see post#3
circuitman is offline   Reply With Quote
Old 06-13-2014, 02:45 PM   #25
Rewards Points: 45
5 hp, 220 Volt, 60 hz, 15 amps,
Old 06-13-2014, 02:56 PM   #26
although the motor says 15 amps, the code shows the load for that motor (which you are supposed to rate that circuit for) at 28 amps...lol
I'm going to sit back and watch a moment.
Old 06-13-2014, 03:04 PM   #27
here giser3546, plug in some numbers.
http://www.electrician2.com/calculat...tor_ver_1.html
Old 06-13-2014, 03:07 PM   #28
Rewards Points: 45
If I'm really aiming for 28 amps that 20 amp plug wouldn't work... would that mean I need to change the plug on the cord since I didn't see any outlets that would work for that plug with more than a 20 amp rating?
Old 06-13-2014, 04:14 PM   #29
Did you plug your values into the calculator?
You will need another electrical service to your house just for that motor
insert motor AC voltage to 220-240
insert Horsepower to 5
click calculate below outputs.
you'll be amazed
Old 06-13-2014, 04:24 PM   #30
Rewards Points: 45
yea... thought I was reading it wrong, ha!
new gas range replacing 220v electric, outlet question jeffzap Electrical 7 11-22-2013 12:43 PM
switch outlet combination phill1 Electrical 4 11-09-2013 08:57 AM
110v outlet from 220v line emstype Electrical 4 06-27-2011 12:58 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
California law & 220v outlet install arminyack Electrical 3 08-03-2009 07:58 PM
