Wiering 220V 20 Amp Straight Blade Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2014, 11:47 AM   #1
Rewards Points: 45
Wiering 220V 20 Amp Straight Blade outlet
I recently got my hands on a large piece of woodworking equipment and need to add a 220 V outlet to my garage for it. I have added regular 110 outlets before with no issue, but never a 220. There is an existing 20 amp double pole breaker in my garage that isn't being used, so I figured I would use that. My only remaining question is the specific outlet that seems to be required is a 3 prong outlet with horizontal prongs similar to this.
http://www.homedepot.com/p/Cooper-Wi...-BOX/203492426
I don't see how a 220 V outlet with 2 hots, 1 neg, and 1 ground could be 3 prong? I have bunches of 12 ga. with two wires (+, -, and grnd) and was hoping I could use that but will get some 12/3 if needed.
giser3546 is offline   Reply With Quote
Old 06-13-2014, 11:51 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
edit.....this is what I get for looking too quick....I thought it was a standard 20a 120Vac plug
never mind my comments
The Following User Says Thank You to ddawg16 For This Useful Post:
jbfan (06-13-2014)
Old 06-13-2014, 11:53 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 482
If the equipment you have does not need a neutral(not -) then don't run one.
Take the white wire you have and tape it, color it red or black, and connect that to the one side of the breaker.
Do the same thing at the receptacle end also.
Old 06-13-2014, 11:54 AM   #4
PoleCat's Avatar
Rewards Points: 1,646
You won't need a neutral wire. Just two hot wires connected to the breaker and the ground.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-13-2014, 11:55 AM   #5
Rewards Points: 45
It says 240 Volt... I'm not familiar with Vac. What outlet would be best? And I dont see how you would plug in any 120V considering one of the prongs is turned 90 degrees.
Old 06-13-2014, 11:57 AM   #6
jbfan's Avatar
Rewards Points: 482
VAC=Volts A/C
Old 06-13-2014, 11:58 AM   #7
PoleCat's Avatar
Does your equipment already have a plug?
Old 06-13-2014, 12:00 PM   #8
Rewards Points: 45
Yes, it has a plug. Two horizontally angled prongs and a ground. Looks like a regular 110 but both of the prongs are rotated 90 degrees.
Old 06-13-2014, 12:02 PM   #9
JOATMON
ddawg16's Avatar
Like this?
Old 06-13-2014, 12:05 PM   #10
PoleCat's Avatar
Maybe this is what he has.
Old 06-13-2014, 12:07 PM   #11
Rewards Points: 45
thats the one
Old 06-13-2014, 12:09 PM   #12
Rewards Points: 45
http://ww2.justanswer.com/uploads/jb...20v_outlet.jpg
Old 06-13-2014, 12:15 PM   #13
Rewards Points: 45
Ok found the one I should probably use, please tell me if I'm wrong. This appears to be what I need.
http://www.lowes.com/pd_27950-43469-...&facetInfo=1.0
Old 06-13-2014, 12:23 PM   #14
Rewards Points: 45
And my regular 12/2 wire will do the job?
Old 06-13-2014, 01:19 PM   #15
Rewards Points: 3,256
Your title says 20 amp which would be the receptacle linked in your first post. This one here is for 30 amps and physically larger.
zappa is offline   Reply With Quote
new gas range replacing 220v electric, outlet question jeffzap Electrical 7 11-22-2013 12:43 PM
switch outlet combination phill1 Electrical 4 11-09-2013 08:57 AM
110v outlet from 220v line emstype Electrical 4 06-27-2011 12:58 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
California law & 220v outlet install arminyack Electrical 3 08-03-2009 07:58 PM
