Wierd Whirlpool Tub - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 10:04 AM   #1
Wierd whirlpool tub
Just moved into a 15 year old home in TN. Ran whirlpool tub (regular fiberglass) bathtub last night and all worked fine, until I tried to turn the pump off. It wouldn't turn off with the in tub switch. I tried it multiple times. Finally got out of the tub, looked under through access panels. I unplugged the pump from it's NON-GFCI receptacle. I plugged it back in and the pump started again. I waited about 2 hours and plugged it back in. The pump worked as it should, turning on and off with the switch in the tub.
1- Can I just install a GFCI plug, or does it need a circuit breaker.
2- Can anyone explain the wierd pump action, and what to do about it.
John Kinney is offline   Reply With Quote
Old 01-08-2011, 10:31 AM   #2
Rewards Points: 1,668
Perhaps the tub switch is bad?
bob22 is offline   Reply With Quote
Old 01-08-2011, 11:10 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
Check the panel, it may have a gfci breaker installed.
Old 01-08-2011, 02:09 PM   #4
DIY staff
Rewards Points: 7,174
Some of the whirlpool switches are air actuated--'switch' is actually a syringe plunger thingy that is attached to a tube that runs to the actual switch--
Tubing or glue may have dried out----Mike--
Whirlpool Energy Saver Water Heater Problem Thurman Electrical 47 02-12-2017 08:24 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 09:12 AM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 07:42 AM
Relocating drain/trap in manufac. home for whirlpool, HELP!!! MikeVila Plumbing 7 12-10-2008 09:04 PM
Whirlpool Duet tryinitmyself Appliances 4 03-17-2008 12:07 PM
