Why Is Wiring Technology So Far Behind? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-24-2007, 03:19 PM   #16
Electrician philosopher
I like the quote on the web site that says that 83% of electrical fires are caused by wiring...duh!!!
Andy in ATL is offline   Reply With Quote
Old 09-25-2007, 05:42 AM   #17
Fixed Wiring
83% of fires are caused by "fixed" wiring
SharonS is offline   Reply With Quote
Old 09-25-2007, 12:59 PM   #18
Rewards Points: 150
There are innovations that tend to make wiring easier. For one, you got those 'backstab' connections found on many newer devices. No need to loop a wire around a screw, making sure it goes in right direction. Instead, you strip about 1/2" of insulation and poke the wire into a hole on an outlet or switch. If neded, wire can be released by pressing on a tab.
Then, I see fixtures coming out that have a connecting module. Instead of holding entire fixture while connecting wires, attach a small module to the box and wire it - then snap the fixture onto the module. Very convenient.
However, for flexibility of connecting disconnecting and capping off wires, I am yet to see anything beat the wirenut.
scorrpio is offline   Reply With Quote
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
How safe is knob and tube wiring? jackdp Electrical 8 10-29-2005 10:50 AM
