Why Is Wiring Technology So Far Behind? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2007, 08:05 PM   #1
Why is wiring technology so far behind?
Hi, I have a question that will probably seem stupid, but I'll ask it anyway. Why is wiring technology in 2007 very similar to what it was 50 years ago? I'm talking mainly about connecting Romex wires together for junction boxes and fixtures. Instead of twisting wire pairs together and capping them with a wire nut (1950's technology?) why doesn't the electrical industry have a standard set of connectors for 120 V, 15-20 amp connections? Something similar to USB connectors on computers, only designed for the currents, wire sizes, and voltages common to household loads? Is this just job security for electricians, or is there a technical reaon why this has not happend?
Thanks,
Arn
Arndavis is offline   Reply With Quote
Old 08-10-2007, 08:44 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
Yes, it's job security. We conspire to make things more expensive for regular folks and intentionally curtail technology.
We have a secret meeting the third Thursday of every month at the Water Buffalo Lodge. You're not invited.
Old 08-10-2007, 09:01 PM   #3
Agent 000
SecretSquirrel's Avatar
Arn, you can pick on any industry you want and the answer will still be the same; it's all about the cost of doing business. There are special electrical connectors and devices available to "plug" wiring together. They are primarily used in manufacturing industries. It's not practical for in house wiring because it is expensive and labor intensive to install, especially when you are not doing it in a mass production mode. When you compete on a job for business, unless it is stipulated in the wiring specifications, then you use standard, conventional and code approved methods to perform the task or else your guys get to sit on the bench not making any money. Put yourself in the homeowner's shoes... do you want it done in an hour with a few 15 cent wirenuts or will you take it in a couple of hours with the 10 dollar connectors? I can assure you that the electricians or contractors for that matter, are not impeding the evolvement of wiring technology. If the electrical component manufacturers had any inkling that something could be improved upon they would be spitting out new products like there was no tomorrow. So maybe this is your calling... you can come up with the next gee-wiz thing for residential wiring installation.
SecretSquirrel is offline   Reply With Quote
Old 08-10-2007, 09:28 PM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
I here that wireless electrical systems have been invented but electricians colluded to cover up the technology.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-10-2007, 09:50 PM   #5
Remodeler
MinConst's Avatar
Easy Speedy you'll blow a fuse
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 08-10-2007, 10:11 PM   #6
Shhhhhhhhh! I was the one to mastermind that.
Don't tell anyone.
Old 08-11-2007, 04:13 AM   #7
Gentlemen, thanks for your responses, and I appreciate the humor. I was not knocking electricians or electrical contractors. They provide an extremely valuable service that requires a lot of skill, knowledge and experience. I also realize that innovation in any industry is generally based on profit margins. I would happily pay $2 or 3$ more for a lighting fixture or junction box that made the installation easier, safer and more efficient. Apparently, most people won't. So I guess I can look forward to another 50 years of twisting those wires together.
Old 08-11-2007, 07:42 AM   #8
Master Electrician
JohnJ0906's Avatar
Speedy, don't forget - It's your turn to make the coffee this month.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 08-11-2007, 09:20 AM   #9
I have gas!
Has there been that much innovation since circuit breakers and push in connections (that apparently aren't that reliable)?
Old 08-11-2007, 11:17 PM   #10
Rewards Points: 334
You really can't compare a low voltage USB computer connection to a permanent higher current connection for a light fixture. One is permanent and desigened for safety and long life, the other is designed for ease of use.
Being in the computer field - 90 % of failures are due to connections, but I've never had a failure on a properly connected wire nut. Of coures I wouln't want to wire nut my plug in memory stick every time I wanted to use it !
tribe_fan is offline   Reply With Quote
Old 08-12-2007, 02:52 AM   #11
Rewards Points: 150
IMHO, I actually would debate the original premise that there haven't been any/much new developments in the last 50 years... Though I only have anecdotal data, but I'm thinking...
1) Fuses changed from the little glass screw in to the safer/easier to use stab-loc ones
2) GFCI outlets instead of those stupid outlets that can only power a razor in the bathroom
3) They tried the aluminum wire for a while and the was not very successfull
4) There have been some changes to the outlets/switches them selves with the strip and stab connections instead of the wrap around the screw pole
The example of finding a replacement for the marret is not really pratical to me. The little sucker works and is easy to take a part for wiring changes and doesn't "eat up" a tail piece is you had to cut short and re-strip the wire...
slakker is offline   Reply With Quote
Old 08-12-2007, 11:08 AM   #12
Master Electrician
JohnJ0906's Avatar
I think conductor insulation has certainly seen improvement.
Materials in general have been improving.
We have methods that have stood the test of time.
Methods that provide flexibility - the good ole' wirenut. Easy to add or remove a wire.
John from Baltimore
One Day at a Time
Old 08-12-2007, 08:01 PM   #13
Hows this?
http://www.idealindustries.com/produ...in/in-sure.jsp
jiggyjack is offline   Reply With Quote
Old 08-15-2007, 08:09 PM   #14
new technology for electrical hazard detection
Speaking of wiring...I just an ad in the Fort Worth newspaper about some new service that can inspect wiring through walls with some new infrared technology. The company was called CurrentSafe. Anybody know anything about them?
richkey is offline   Reply With Quote
Old 09-24-2007, 04:14 PM   #15
CurrentSAFE
I found additional information about CurrentSAFE on their website: www.currentsafe.com
Check it out
SharonS is offline   Reply With Quote
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
How safe is knob and tube wiring? jackdp Electrical 8 10-29-2005 11:50 AM
