Why, Why, WHY! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 11:23 AM   #1
Rewards Points: 172
Why, why, WHY!
My newly finished basement is just about done, and I never ran the cable line. What are some tricks and tools that can be helpful in running the wire into and through the wall? I can run it along the side of the house which, luckily, is the same side as the wall where I want it. Then I should be able to drill it low enough to get to the basement, and not have to go from the first floor to the basement. But I'd still have to find where it came in, above the top plate of my framing. Then run it down the wall.
nateshirk is offline   Reply With Quote
Old 12-28-2011, 11:32 AM   #2
Rewards Points: 240
First thing is to calm down. Of course this was a giant oversight, but not the end of the world.
Now, what do you mean by a cable line? The cable from the panel? We need specifics here. Please tell us what you mean.
Old 12-28-2011, 11:33 AM   #3
Licensed electrician
Rewards Points: 1,876
I think the OP wants a cable for a TV.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
gregzoll (12-28-2011), J. V. (12-28-2011)
Old 12-28-2011, 11:38 AM   #4
joed's Avatar
Rewards Points: 13,712
If you want it to come down the wall I think you are going to have to cut a hole in the drywall and patch it unless you have a dropped ceiling.
Old 12-28-2011, 12:09 PM   #5
If you are skilled with a fische tape, or know someone that is, there are what's called flex bits which are typically 5' long drill bits with an auger tip. You can bend it through a cut in hole at the height that you want and drill the top plate. You could then push the wire from outside the house above the top plate and "snag" it and pull it down.
It takes a bit of experience though not to destroy your wall in the process, but it can be done.
2 people and a lot of patience you can fische wires through this issue.
lowvolter is offline   Reply With Quote
Old 12-28-2011, 12:22 PM   #6
Rewards Points: 6,652
Basement is finished, need CATV or Ethernet, but do not know if the walls are insulated, or what is up in the ceiling. Easy way is to use panduit and paint it the same color as the wall finish. From there, you have to figure how to get it upstairs, which may mean then cutting into the drywall to pull into the various rooms. This is why it should be planned into the beginning before even putting materials to the structure.
Old 12-28-2011, 12:41 PM   #7
is the tv going to be hooked to a cable box? if it is most cable boxes have an hdmi out and most newer tv's have hdmi plugs. they make a wireless hdmi transmitter. my wife wants to get one cause she doesnt like the cable box sitting by the tv. with the wireless we can put the cable box anywhere. they also have wireless cable transmitters for regular cable tv. most hd tv's are wireless capable for network connecting.
Old 12-28-2011, 03:53 PM   #8
FYI - I had a recent bathroom remodel project which took me 2 years to complete. Everything under the sun interrupted my work on that project... But I was glad it took so long as I had plenty of time to think about adding this wire or that wire, a certain plumbing design, etc.
So I guess sometimes procrastination is a good thing!
Billy_Bob is offline   Reply With Quote
Old 12-28-2011, 03:59 PM   #9
Julius793's Avatar
I took you TWO years to decide where to put the wires????!!!! I wouldn't even call that procrastination!
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-28-2011, 04:05 PM   #10
Actually I learned after about one year that some new toilets are electric or have seats which require a dedicated outlet. So I added an outlet for the toilet on its own circuit. I never would have thought of that had I finished the job quickly...
Old 12-28-2011, 04:07 PM   #11
Julius793's Avatar
I'm just teasing no need to answer
Old 12-29-2011, 12:40 PM   #12
Rewards Points: 115
I'm trying to convince my wife that I am not a procrastinator just a big thinker. A slow, big thinker.
pokey is offline   Reply With Quote
