Why Use Halogen Lights Instead Of Regular Bulbs For Outdoor Lighting? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-12-2009, 09:44 PM   #1
Rewards Points: 682
Why use halogen lights instead of regular bulbs for outdoor lighting?
I just installed a motion sensor light. Right now I'm using regular bulbs in it while deciding if I should replace them with those big halogen lights.
Is there a reason for using halogen lights instead of bulbs, besides the fact that they are brighter? Are they safer, lets say, during a rain? Those halogens sure use a lot more electricity.
darsunt is offline   Reply With Quote
Old 10-12-2009, 09:53 PM   #2
" Euro " electrician
frenchelectrican's Avatar
The halogens are more brighter due the lumies per watt just the same idea with Miles per gallon on gazoline.
Yeah and they look more whiter in colour as well and they do come variation of size and wattage and size.
What wattage you are running now ?
Just keep in your mind some motion senser just can't handle very powerfull halogen luminaire[s]
Merci,Marc
Old 10-12-2009, 11:16 PM   #3
I use a CFL floodlight - uses 65w = equiv they say to 300w
I haven't tried it with a sensor, puts out a lot of light
Old 10-12-2009, 11:36 PM   #4
Rewards Points: 682
The manual says 300 watt max. incandescent. I don't know if that means wattage used or just how bright the lights are.
Old 10-12-2009, 11:38 PM   #5
If your manual stated 300 watt max then you can use any type of bulbs up to total of 300 watt max but only if used for on and off real quick the halogen can do better task and there are few diffrent size halogen luminaire you can use
Are you using this to lit up the yard { this is most common way to use med to large halogen flood light to come on }
or other use like entrance way near the door ?
Merci,Marc
Old 10-13-2009, 11:38 AM   #6
Rewards Points: 682
I want to illuminate the back of the house as a security measure. The motion sensor covers a small enclosed yard and an alley
Old 10-13-2009, 10:58 PM   #7
Then my suggest that you go to the big box store and see the slection of the halogen motion luminaire there is few diffrent variations you can use and options as well.
They even have double 150 watts halogen flood light verison as well so take a look to see what it will suit your need { I know there is more than 15 differnt style and types for halogen flood luminaire }
Merci,Marc
Fire Hazard worry on Low wattage recessed lights usng 50w halogen bulbs jomieblumreich Electrical 7 08-15-2009 05:20 PM
Newbie's lights flicker and bulbs blow out MA_in_PC_Fla Electrical 11 05-21-2008 03:34 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 06:02 PM
Halogen flood lights chicagonyc Electrical 5 07-15-2006 11:11 PM
