Why Two Holes For GFCI Hot - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 01:13 PM   #1
Rewards Points: 664
Why two holes for GFCI hot
GFCI outlets have two holes for incoming hot wires on the line side. Why would you need to have power supplied twice? Yes, I am sure this is probably a dumb question.
crescere is offline   Reply With Quote
Old 08-24-2012, 01:55 PM   #2
Mad Scientist
You might want to feed power through the GFCI to the rest of the circuit, without actually protecting it on the load side of the GFCI. Just like when you wire a circuit using both sets of screw terminals on a standard receptacle.
McSteve is offline   Reply With Quote
Old 08-24-2012, 06:22 PM   #3
"So I Re-Wired It"
MisterZ's Avatar
in other words, only one screw gets power. the other "feeds" power to other devices down stream.
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-24-2012, 08:16 PM   #4
Not exactly sure what you are referring to but I can give you 2 reasons.
1-Assuming this is just the "line side" of the GFI, then the two holes are for two wires. You are not feeding it twice, you are bringing in the power and using the GFI as a splice point for power out on another wire. The wire going out is NOT GFI protected.
2-Assuming the two holes are (1) "Line Side" and (2) "Load Side" - one hole is for incoming power and the other is for feeding a circuit as protected by that GFI.
parman is offline   Reply With Quote
Old 08-24-2012, 09:51 PM   #5
Rewards Points: 664
To send power downstream I am used to just using a pigtail and making one connection to the outlet. I think you are ll saying I can send power in and then pass power downstream (unprotected) using the second set of holes on the line side.
I just saw a GFCI that had two sets of wires going into the line and two sets of wires going out from the load. What were they trying to accomplish?
Old 08-24-2012, 09:54 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You're not feeding it twice, you are using the device as a splice.
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
Freestanding deck with water in the holes. HHHEEEELLLPPP bassheadjohn Concrete, Stone & Masonry 28 08-23-2012 10:19 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Series of holes in periphery of basement slab BalowskiJ Building & Construction 4 04-18-2011 02:49 PM
Alternatives for fixing holes in tile roof felt Squash_Pro Roofing/Siding 4 05-13-2010 07:20 PM
