Why Are Switches Placed Furthest From Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-20-2012, 01:53 PM   #1
Why are switches placed furthest from light?
This really has been a pet peeve of mine in my house where the switch on the left controls the light upstairs to the right, and the switch on the right controls the light downstairs to the left. The middle controls the outside light which is fine.
Also at work theres a few large rooms where the left switch controls the lights on the right and the right switch controls the lights on the left.
I asked someone about this one time and they said that they read it was code to do it that way. They did not know the reason behind it. I'm curious if it is really code to wire switches this way and WHY is it code to cross the lines like that? I would like to rewire my switches at home personally so the left switch controls the left light and vice versa, but if there is a particular safety reason why its the way it is, I will leave it be and continue to "think backwards" when flipping switches. I just think it would make sense for the switch on a multi-switch plate to control the light it is closest to.
Uploaded with ImageShack.us
cypherx is offline   Reply With Quote
Old 06-20-2012, 02:24 PM   #2
joed's Avatar
Rewards Points: 12,900
What is the most common direction you go when you enter that door? If it is upstairs then it makes sense to me to have the upstairs light switch be the first and easiest to hit when you enter the door.
There is no code on this and you can switch the locations if you prefer them in a different order.
The Following User Says Thank You to joed For This Useful Post:
Code05 (06-20-2012)
Old 06-20-2012, 03:21 PM   #3
Rewards Points: 672
I think this is one of those "taste's great vs. less filling" arguments (or prong on three prong up vs. down) (or toilet flange flush vs. toilet flange above).
While I value joed's input, I am an anal CPA and agree with the OP that the switches should be direction oriented to the fixtures.
OP, if you are handy, then you can orient the switches to however you want to.
B
Beepster is offline   Reply With Quote
Old 06-20-2012, 03:29 PM   #4
Rewards Points: 826
If this is a pet peeve then your life is very good! Go buy a lottery ticket.
curiousB is offline   Reply With Quote
Old 06-20-2012, 03:40 PM   #5
I usually enter through the garage door which for my house means I am coming up from those downstairs.
Its a bi-level and while that door on the landing is the front entrance, it's easier for me to go through the garage.
Yeah there's no big issue with me doing simple wiring... I can swap it but I was just curious if there was a particular reason or code stating why it was originally wired this way.
Old 06-20-2012, 04:23 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
No code at all on this, but I do consider it poor practice.
I always try to arrange multi-gang switches in a logical order as to placement of the lights.
Speedy Petey is online now   Reply With Quote
Old 06-20-2012, 06:07 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You will never please everyone... I used to install the OS light switch closest to the door and half the people would complain that they would rather the interior light be in that location... go figure.
Old 06-20-2012, 06:09 PM   #8
Rewards Points: 6,652
Even easier, just get some remote controlled lighting, and that way, when you pull in, you can just hit the remote on your keychain to turn them on. What is really worst, is when you have the mystery switch in the mix, and even the builder can never tell you what it does.
Old 06-20-2012, 06:22 PM   #9
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I used to get service calls for one receptacle in each bedroom didn't work. And one switch didn't do anything. Or my favorite service call to reset the GFI. Duh. Here's your sign.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-20-2012, 06:25 PM   #10
electures's Avatar
Same here
Old 06-20-2012, 06:36 PM   #11
E2 Electrician
agree, my favorite is lights are not working... me: "did you change the lamp?" customer: "Yes, and it still doesn't work" Show up and change the lamp... why do people lie about that stuff?
Old 06-20-2012, 07:10 PM   #12
Missouri Bound's Avatar
Simple answer....they say the did because if they admit it you would think they are stupid.....but they are OK knowing themselves that they are stupid for not checking the lamp first.
Do you want it your way or the right way?
Old 06-20-2012, 07:15 PM   #13
E2 Electrician
I always suggest over the phone that they check the lamp first, and they still insist it's not that lamp... must be some really lonely people in this world, at least to pay to see me.
Old 06-20-2012, 08:22 PM   #14
joed's Avatar
Put the switches where the customer wants them. He asked for a reason why they would be where they are. I gave one possible reason.
Old 06-21-2012, 05:21 PM   #15
Heh,
Well one good thing is I have been changing out all the brown backstabbed outlets and switches for new white ones and I hook them back up with the screw terminals. All the back stabbed ones seem pretty tight here, but I heard some pretty bad stories with them coming loose for some people.
Circuit trips with 2 light switches sylercider Electrical 3 12-05-2010 10:09 PM
How many light switches? Abs777 Electrical 10 11-05-2010 12:17 PM
3 way switches with light load on both ends boutwater Electrical 2 03-07-2010 12:05 PM
Two Ceiling Light Fixture switches suddenly acting flakey!!! babalina Electrical 5 10-12-2009 07:52 PM
adding an additional light to 2 3-way switches basement_guy Electrical 10 07-20-2008 09:23 AM
