-   -   Why are switches placed furthest from light? (http://www.diychatroom.com/f18/why-switches-placed-furthest-light-147706/)
cypherx 06-20-2012 02:53 PM
This really has been a pet peeve of mine in my house where the switch on the left controls the light upstairs to the right, and the switch on the right controls the light downstairs to the left. The middle controls the outside light which is fine.
Also at work theres a few large rooms where the left switch controls the lights on the right and the right switch controls the lights on the left.
I asked someone about this one time and they said that they read it was code to do it that way. They did not know the reason behind it. I'm curious if it is really code to wire switches this way and WHY is it code to cross the lines like that? I would like to rewire my switches at home personally so the left switch controls the left light and vice versa, but if there is a particular safety reason why its the way it is, I will leave it be and continue to "think backwards" when flipping switches. I just think it would make sense for the switch on a multi-switch plate to control the light it is closest to.
http://img254.imageshack.us/img254/1...chquestion.jpg
Uploaded with ImageShack.us
joed 06-20-2012 03:24 PM
What is the most common direction you go when you enter that door? If it is upstairs then it makes sense to me to have the upstairs light switch be the first and easiest to hit when you enter the door.
There is no code on this and you can switch the locations if you prefer them in a different order.
Beepster 06-20-2012 04:21 PM
I think this is one of those "taste's great vs. less filling" arguments (or prong on three prong up vs. down) (or toilet flange flush vs. toilet flange above).
While I value joed's input, I am an anal CPA and agree with the OP that the switches should be direction oriented to the fixtures.
OP, if you are handy, then you can orient the switches to however you want to.
B
curiousB 06-20-2012 04:29 PM
If this is a pet peeve then your life is very good! Go buy a lottery ticket.
cypherx 06-20-2012 04:40 PM
I usually enter through the garage door which for my house means I am coming up from those downstairs.
Its a bi-level and while that door on the landing is the front entrance, it's easier for me to go through the garage.
Yeah there's no big issue with me doing simple wiring... I can swap it but I was just curious if there was a particular reason or code stating why it was originally wired this way.
Speedy Petey 06-20-2012 05:23 PM
No code at all on this, but I do consider it poor practice.
I always try to arrange multi-gang switches in a logical order as to placement of the lights.
stickboy1375 06-20-2012 07:07 PM
12 Attachment(s)
You will never please everyone... I used to install the OS light switch closest to the door and half the people would complain that they would rather the interior light be in that location... go figure.
gregzoll 06-20-2012 07:09 PM
Even easier, just get some remote controlled lighting, and that way, when you pull in, you can just hit the remote on your keychain to turn them on. What is really worst, is when you have the mystery switch in the mix, and even the builder can never tell you what it does.
electures 06-20-2012 07:22 PM
I used to get service calls for one receptacle in each bedroom didn't work. And one switch didn't do anything. Or my favorite service call to reset the GFI. Duh. Here's your sign.
electures 06-20-2012 07:25 PM
Same here
stickboy1375 06-20-2012 07:36 PM
12 Attachment(s)
agree, my favorite is lights are not working... me: "did you change the lamp?" customer: "Yes, and it still doesn't work" Show up and change the lamp... why do people lie about that stuff?
Missouri Bound 06-20-2012 08:10 PM
Simple answer....they say the did because if they admit it you would think they are stupid.....but they are OK knowing themselves that they are stupid for not checking the lamp first.:laughing:
stickboy1375 06-20-2012 08:15 PM
12 Attachment(s)
I always suggest over the phone that they check the lamp first, and they still insist it's not that lamp... must be some really lonely people in this world, at least to pay to see me. :)
joed 06-20-2012 09:22 PM
Put the switches where the customer wants them. He asked for a reason why they would be where they are. I gave one possible reason.
cypherx 06-21-2012 06:21 PM
Heh,
Well one good thing is I have been changing out all the brown backstabbed outlets and switches for new white ones and I hook them back up with the screw terminals. All the back stabbed ones seem pretty tight here, but I heard some pretty bad stories with them coming loose for some people.
