Why Are Some Furnaces Wired With BX/Armored Cable? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 08:35 PM   #1
Rewards Points: 87
Why are some furnaces wired with BX/Armored cable?
I notice that in many homes, the furnace and in some cases air conditioning handling units are wired with BX or Armored Cable. I have also seen whole-house fans wired this way. This is in homes with no other armored type wiring. Do today's codes mandate BX or Armored cables in these situations?
Perry401 is offline   Reply With Quote
Old 05-30-2011, 09:17 PM   #2
Licensed electrician
Rewards Points: 1,024
No code mandate for this. Perhaps someone ran the metallic cables to provide more protection for the wiring.
Old 05-30-2011, 09:41 PM   #3
Master Electrician
Rewards Points: 3,678
Personal preference of the contractor or installer.
brric is online now   Reply With Quote
Old 05-30-2011, 09:54 PM   #4
Rewards Points: 6,652
Protection from damage. Harder to cut a Armored cable vs. Romex.
Old 05-30-2011, 10:07 PM   #5
There are literally thousands and thousands of home wired this way, here in Ontario, Canada.
At one time it was a code requirement and may still be.
In my present home, Romex feeds the off and on switch and then BX is run into the furnace.
Its in my mind that BX cable insulation has a higher temperature rating. Or at least used to have.
Its been 15 years since I worked in this area, so I doubt that I have current knowledge in this regard. The last furnace that I wired was in 1989.
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 09:01 PM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 11:20 AM
broken drum snake cable, how to fix? confusedDIY Plumbing 1 03-18-2010 09:38 AM
Running Sky+ cable bookersbeauty Electrical 1 04-09-2009 08:12 PM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 10:04 AM
