Why Is This Outlet Flopping On The Floor - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 03:23 PM   #1
Rewards Points: 2,072
why is this outlet flopping on the floor
just pulled my stove out for the first time and it was filthy behind there. Why is the stove outlet laying on the floor and does this hurt anything?
Startingover is offline   Reply With Quote
Old 10-31-2012, 03:48 PM   #2
Rewards Points: 332
Attachment 59777
The installer was lazy. I'd screw it to the wall, after cutting power of course.
sgip2000 is offline   Reply With Quote
Old 10-31-2012, 03:55 PM   #3
Rewards Points: 13,296
Kill the power, remove the cover, two screws in the bottom plate.
If you find out someone has built the floor up to high with layers of plywood, I'd open up that drywall add a 2 X 4 block between the studs nailed to the bottom plate, install your patch and then screw it to the plate.
Old 10-31-2012, 04:40 PM   #4
Experienced
Jackofall1's Avatar
Not sure about your situation but the last one of those that I installed (for a stove I presume) mounting to the wall may cause the stove to be pushed out from the wall too far. I mounted mine to the floor as there was an opening in the back of the stove that was about 6 or so inches high.
Just make sure you kill the power before you attempt anything.
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 10:32 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
