-   -   Why Not Two 2-Way dimmers ? (http://www.diychatroom.com/f18/why-not-two-2-way-dimmers-4910/)
Piney 11-19-2006 08:59 PM
Greetings--
I have a two-way light (operated by either of two switches). I assumed that I could replace the switches with two dimmers, thus allowing me to operate the lights and dim them from either switch.
Apparently not so. The instructions said only one dimmer per circuit.
Why so ?
mdshunk 11-19-2006 09:00 PM
There's no such thing as a "two way switch" of any sort. They're called "3 way switches"
No, you cannot dim from two locations with ordinary 3 way dimmers. There are specialized "master/slave" dimmers that you can do this, however.
troubleseeker 11-24-2006 10:25 PM
[quote=mdshunk;24184]There's no such thing as a "two way switch" of any sort. They're called "3 way switches"
No, you cannot dim from two locations with ordinary 3 way dimmers. There are specialized "master/slave" dimmers that you can do this, however.[/quote
I was interested to see your comment about the master/slave dimmers. I have never heard of this, but will definately look into it. It is alway hard to get customers to understand that you cannot control with two dimmers on a 3 point set up. They always look like they believe I'm just telling them a story to cover for a mistake by the electrician.
mdshunk 11-24-2006 10:52 PM
Originally Posted by troubleseeker (Post 24680)
I was interested to see your comment about the master/slave dimmers..
The Lutron 'Maestro' dimmers are what I use in that case. You use one smart dimmer, and up to 9 remote dimmers. With that system, you cannot use any mechanical 3-way or 4-way switches for that switching arrangement. They all have to be part of the Maestro system. I think about 100 bucks, wholesale, gets you a master dimmer and a couple remotes. Nice upsell, if they have their heart set on multiple location dimming.
jwhite 11-25-2006 06:55 AM
That is true in the USA, but in many other countries they say two way when there are two switches, three way when there are three swithches, four way when there are four, etc...
mdshunk 11-25-2006 08:36 AM
Horsehockey. What country would that be? Post some sort of official link. I've got a UK book right here on my shelf explaining why three way swiches are so called, as they call conductors "ways" sometimes.
jwhite 11-25-2006 09:36 AM
I only know from posters from many coutries and what they say on message boards.
jwhite 11-25-2006 09:42 AM
a quick google did produce some results.
http://www.ultimatehandyman.co.uk/two_way_lighting.htm
http://www.diynot.com/pages/el/el031.php
http://qingtai.en.alibaba.com/produc...luminated.html
joed 11-25-2006 06:12 PM
That is a very interesting way to switch a light from two places. I have never seen a setup like that with the commons connected together.
cezeta 12-31-2008 06:47 AM
depends where you are located, over the past 20 years i have worked in the uk scandanavia and europe. we call two switches on one circuit "2 way" and any more than two "intermediate switches" which you may call 4 way.
2 way (or 3 way depending on terminology) dimmer switching is common, I use the "mk" dimmers in europe.
220/221 12-31-2008 10:33 AM
In the 70's we had an entirely different meaning for 3 ways.
Why so ?
The 3way circuit goes from point A, the power, thru the switches to point B, the light. Once the power is dimmed it can't be undimmed.
The master slave thing needs a bit of rewire and you will need a voltage tester. If I remember correctly, both switches need power, the master needs the switch leg and there is one wire connecting them.
AllanJ 12-31-2008 12:48 PM
If you have a correctly wired 3 way switch setup, you should be able to convert that to a master-slave 3 way dimmer setup without adding wires.
For a switch loop the 3 conductors: switched-traveler-traveler become neutral-hot-control. For in-line switches you already have neutral and the travelers become hot and control. The dimmer dial goes where the feed to the lights branches off and the remote dial goes in the other location.
If you install non-master-slave dimmers in a 3 way switch setup you may find that a location can vary the light between dim and bright but not off, or between dim and off but not bright.
Yoyizit 12-31-2008 01:43 PM
Are you the same Shunk that sued his high school?
BTW, on paper at least,
if one conventional dimmer is on full, the other will have full control.
If one is on at half intensity, the other will have control from zero to half.
It's kind of an "analog AND gate".
It might have application somewhere, but probably not here.
InPhase277 12-31-2008 03:11 PM
Another instance of someone replying to a thread that's over 2 years old:laughing:
Yoyizit 12-31-2008 04:33 PM
See bandwagon, jump on. . .
