Why No Ground Wire? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2009, 09:39 PM   #16
people are notorious for not connecting the ground wire to switches.
It wasn't required until recently. If it's a metal grounded box, it still isn't required.
220/221 is offline   Reply With Quote
Old 09-22-2009, 09:42 PM   #17
I actually just noticed a switch in my house that doesn't have a ground screw
The ground is looped under/around one of the screws that holds the switch in
Blue box, once more thing on my list to replace/fix
Old 09-22-2009, 10:19 PM   #18
Thumbs up
Issue of connecting Ground wire to Sw./Recept.!
Exactly my point. Where there is Ground continuity (to the panel) it is not necessary. IMO (and it's a no-brainer) the reason the NEC tightened the rules about Grounding, is because Plastic boxes and PVC (in Plumbing) are widely used, requiring dedicated ground connections. Whereas, in years past, any professional (including DIY'rs.) installation would automatically take care of this. (Now more than Ever)Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
no ground wire jamesm113 Electrical 9 08-30-2009 09:40 AM
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 06:37 PM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 12:33 PM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 05:28 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
