#1 |
Why doesn't my switch work?
I am installing a new service for a kitchen light, and have made all of the proper connections yielding power, but the switch doesn't work. I do not have the ground hooked to the switch box, would this effect the switch?
#2 |
Electrical Contractor
No, and without more details we can only guess what is wrong.
Pics, or wiring diagrams will help tell the story.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#3 |
Going to have to let us in on how you wired it and what type light you have.
#4 |
Licensed electrician
If the box is metallic the ground should be connected to it and the switch. If the box is plastic you need to connect it to the switch.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
| The Following User Says Thank You to Jim Port For This Useful Post: | mikenkat1 (12-01-2012) |
#5 |
Ok I know that it is the proper thing to do to have the ground hooked up, but I didn't think it would effect the switch operation if it wasn't.
#6 |
Licensed Electrician
With the information given, there is no way to help you.
Not a fan of the new layout.
Answers based on the National Electric Code. Always check local amendments. |
#7 |
New service?
#8 |
The ground not being connected will not affect the operation of the switch. If you hooked it up correctly it would be working so I think you made a mistake. Tell us how you ran the cables and hooked them up. Then we can tell you where you went wrong.
Do not PM with questions that can be asked in a forum. I will not respond. |
| Display Modes | |
| Converting switch to switch & constant power outlet | BCeagle08 | Electrical | 4 | 01-29-2012 10:34 PM |
| Illuminated switch ??? | dave95sps | Electrical | 5 | 05-29-2011 06:11 PM |
| 3-way light with a twist | Jeepsail | Electrical | 14 | 05-18-2010 02:24 AM |
| single gang single pole switch on fan | fabian | Electrical | 14 | 03-05-2009 02:11 AM |
| Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) | inspectator | Electrical | 8 | 08-07-2007 02:19 AM |
