Why Doesn't Light Switch Control My Outlets Anymore? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 07:59 PM   #1
Why doesn't light switch control my outlets anymore?
One of our light switches used to control the top plug on our outlets. Now they are all 'on' and the switch isn't controlling anything. What happened?
saksams is offline   Reply With Quote
Old 12-14-2010, 08:42 PM   #2
Assuming no modifications to the outlet or wiring, my initial instinct is to suspect failed switch. Regardless, this should not be too difficult to troubleshoot.
oberkc is offline   Reply With Quote
Old 12-14-2010, 09:51 PM   #3
joed's Avatar
Rewards Points: 12,944
Most common cause is you changed the receptacle and didn't break the tab on the hot side. Or the switch is bad.
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Replacing light switch in series wired home - help! kellykate Electrical 6 04-16-2009 06:37 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 03:06 PM
Wall outlets stay charged even when light switch is turned off proofer Electrical 33 01-25-2008 04:43 PM
