Old 09-27-2012, 09:29 PM   #1
Question
why does an office coffee maker need 2 hots?
i noticed the cord of our office coffee maker is 12/3. it has hot water in addition to 2 warming plates. is it that brewing water takes one hot and and the warmers take another. i just thought that something that small could get away on a single hot.
amakarevic is online now   Reply With Quote
Old 09-27-2012, 09:43 PM   #2
Master Electrician
Is that an SO cord? If so, 12-3 SO has only three conductors, white, black, green.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
amakarevic (09-28-2012)
Old 09-27-2012, 09:47 PM   #3
Electrical Contractor
kbsparky's Avatar
Flexible cords markings indicate all conductors, including the ground wire.
A cord marked 12/3 would have a black, white, and green conductor.
ONE hot wire, one neutral wire, and one ground wire.
You do have 2 current-carrying conductors. You do not have 2 "hots".
-KB
Old 09-27-2012, 09:53 PM   #4
Heating elements usually use a lot of electricity !
A water heating element could easily be 2000w or more !
The two warming plates could easily be 1000w a piece !
Thats 4000w, thats not a small amount of power !
Your more likely to find a 40A outlet at 220v than 120v !
I am only guessing at these figures as I cant see the name plate,
But I think they would be reasonable !
dmxtothemax is offline   Reply With Quote
Old 09-27-2012, 10:21 PM   #5
Semi-Pro Electro-Geek
As others have noted, 12/3 flexible cord only has three conductors. But some commercial coffee makers are 120/240V, requiring two hots, neutral, and ground. They often draw more than the 2400W maximum available on a 20A 120V circuit, so they rely on a 15 or 20A 240V circuit for all the heating power, and use 120V for controls. It takes a lot of power to heat water. Even a small home coffee maker is usually over 1000W.
mpoulton is offline   Reply With Quote
Old 09-27-2012, 11:23 PM   #6
Most electric kettles in Australia are 2000 to 2400w.
Havent seen any as small as 1000w.
Unless it is different in the USA !
Old 09-28-2012, 12:18 AM   #7
I think there needs to be a seperation of residential and commercial coffee makers. I see many residential units in small offices. I also have worked on large 5 gallon 3-phase units.
A 12/3 cord is just a regular cord. It shouldn't be 220V. A brand new Bunn VP17-3 is only rated for about 14 A (3 total warming plates). It's a resistive load so it does not need a 20A recept. 1000W is more than hot enough to BOIL a very LARGE pot of water. Those warmers should only be about 100-150W.
The only time you start getting into 220V is into larger or higher volume brewers that require fast boiling. Start seeing more 220V in commercial kitchens + cafe espresso machines.
Protocol. is offline   Reply With Quote
Old 09-28-2012, 05:47 AM   #8
Licensed Electrician
k_buz's Avatar
I am currently wiring a brand new Dunkin Donuts and they have two types of regular coffee makers: a single brew with two warming plates and a dual brew with 4 warming plates. The dual brew requires a 50A 120/208 single phase circuit, and the single brew requires a 20A 120/208 circuit.
Location...Location...Location
k_buz is online now   Reply With Quote
Old 09-28-2012, 10:53 AM   #9
What does the outlet look like which this plugs into? Various types...
http://www.generatorjoe.net/html/web...quailplug.html
And on the back of the unit should be a "name plate". That should say what voltage and amperage/wattage the unit is. What does that say?
Billy_Bob is offline   Reply With Quote
need help with office 2007 Handyman4Hire PC Repairs & Upgrades 16 02-23-2012 10:59 AM
Cuisinart Coffee Maker DGB-625 Proogramming Problem famousredhead Appliances 0 07-18-2011 03:34 PM
Heat issue in the office repoman HVAC 1 05-08-2010 12:12 PM
120/208v coffee maker hook-up ? Andy-n-ATL Electrical 23 04-27-2010 08:36 PM
Ice Maker Not Getting Water sgorak General Discussion 3 10-27-2008 09:02 PM
