Why Does My Radial Arm Saw Keep Tripping The Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 05:02 PM   #1
Question
Why does my radial arm saw keep tripping the breaker?
My radial arm saw (11 amp motor) often trips the circuit breaker(15 amps)
Any thoughts why?
Dennis
djtjak43 is offline   Reply With Quote
Old 04-14-2009, 05:21 PM   #2
We had this problem already. The "often" is the key. Half the time the saw will be turned on at the peak of the AC waveform.
As a test, put the saw at the end of a small gauge extension cord. You're adding series resistance to the circuit.
There is also a table of allowable extension cord lengths vs. allowable gauge numbers in your saw manual. #10 is 2 milliohms/ft, #12 is 3.2, #14 is 5.2.
See the table halfway down the link
http://www.magnet.fsu.edu/usershub/s...ensioncord.pdf
Another way that should work to reduce this problem is to spin the saw blade [careful] in the correct direction before turning on the motor.
Old 04-14-2009, 06:24 PM   #3
High output electric motors often draw more than their amperage rating on startup, also known as "in rush".
In the central vac industry in the late 90's this caused several years of turmoil as there were numerous underated relays burning out, a problem caused by new higher rpm motors, high output motors being used due to increased home sizes.
Add in rush to an extension cord or another device on the line and there goes your breaker....
Chemist1961 is offline   Reply With Quote
Pool Main breaker keeps tripping beckyreyes Electrical 12 08-11-2013 04:06 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 01:47 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
HW tank breaker tripping arichard21 Electrical 6 10-31-2007 04:13 PM
