Why Do These Old Flourescent Fixtures Fail? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2010, 08:32 PM   #1
Rewards Points: 682
Why do these old flourescent fixtures fail?
We have a kitchen flourescent fixture that would sometimes not start on cold nights, other times take an hour or so to get started. The new fixture I replaced it with works fine.
Why do these old fixtures start having problems starting, especially when it is cold? Could I have just replaced the ballast?
darsunt is offline   Reply With Quote
Old 12-31-2010, 08:38 PM   #2
Gymschu's Avatar
Rewards Points: 648
The problem is generally with the bulbs.......the type of gas used in the older flourescent bulbs was a problem in cold environments. Bulbs today are made with Krypton gas, I believe, and work much better in cold conditions. I think buying a whole new light fixture was the way to go.
Old 12-31-2010, 08:39 PM   #3
Yeah, usually either the ballast fails or the starter
Cost of the ballast, trouble to wire a new ballast in an old fixture you are better off with a new fixture
Did you try new bulbs ?
Old 01-01-2011, 01:50 PM   #4
Rewards Points: 150
Fluorescent lights don't start well in cold temperatures - especially the old "preheat" type. The name should help explain why.
This is not a sign of anything failing. It's just the way fluorescent lights are.
emolatur is offline   Reply With Quote
Old 01-01-2011, 01:59 PM   #5
You can get low temperature fixtures that are designed to start in colder temperatures. I use these in my garage, which is unheated. They do start up immediately even in cold weather, but it takes the bulbs a few minutes to warm up to full light output.
clashley is offline   Reply With Quote
Old 01-01-2011, 02:15 PM   #6
Household Handyman
Rewards Points: 1,408
Hey "clashley", I'm in Albany, Ga. also and do the same: I turn my fluorescent lights on in my shop in November and by June they are at full brightness .
Old 01-01-2011, 02:35 PM   #7
Rewards Points: 154
ballasts
you can get electronic ballasts and they are great in the cold
awdblazer is offline   Reply With Quote
No power to light fixtures or switch in garage mrsirmrman Electrical 5 09-29-2010 03:36 PM
Master Bathroom Fixtures mpt1123 Plumbing 1 03-01-2009 04:08 PM
Replacing Bathroom Light Fixtures, going from one to two. diynewb Electrical 3 11-25-2008 10:16 AM
Advice on replacing bathroom fixtures t1000 Plumbing 3 07-11-2008 02:42 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
