-   -   Why do these old flourescent fixtures fail? (http://www.diychatroom.com/f18/why-do-these-old-flourescent-fixtures-fail-90916/)
darsunt 12-31-2010 08:32 PM
We have a kitchen flourescent fixture that would sometimes not start on cold nights, other times take an hour or so to get started. The new fixture I replaced it with works fine.
Why do these old fixtures start having problems starting, especially when it is cold? Could I have just replaced the ballast?
Gymschu 12-31-2010 08:38 PM
The problem is generally with the bulbs.......the type of gas used in the older flourescent bulbs was a problem in cold environments. Bulbs today are made with Krypton gas, I believe, and work much better in cold conditions. I think buying a whole new light fixture was the way to go.
Scuba_Dave 12-31-2010 08:39 PM
Yeah, usually either the ballast fails or the starter
Cost of the ballast, trouble to wire a new ballast in an old fixture you are better off with a new fixture
Did you try new bulbs ?
emolatur 01-01-2011 01:50 PM
Fluorescent lights don't start well in cold temperatures - especially the old "preheat" type. The name should help explain why.
This is not a sign of anything failing. It's just the way fluorescent lights are.
clashley 01-01-2011 01:59 PM
You can get low temperature fixtures that are designed to start in colder temperatures. I use these in my garage, which is unheated. They do start up immediately even in cold weather, but it takes the bulbs a few minutes to warm up to full light output.
Thurman 01-01-2011 02:15 PM
Hey "clashley", I'm in Albany, Ga. also and do the same: I turn my fluorescent lights on in my shop in November and by June they are at full brightness :thumbup:.
awdblazer 01-01-2011 02:35 PM
ballasts
you can get electronic ballasts and they are great in the cold
