Why Do Lights Flicker ? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2007, 12:08 AM   #1
Rewards Points: 1,062
Question
why do lights flicker ?
and how do you stop them from oing that ?
thx,
- a
Old 05-26-2007, 03:02 AM   #2
leave them off.
send_it_all is offline   Reply With Quote
Old 05-26-2007, 09:24 AM   #3
What kind of lights? When to they flicker?
Master Electrician
jwhite is offline   Reply With Quote
Old 05-26-2007, 04:37 PM   #4
Home Improvement Guy
ron schenker's Avatar
Originally Posted by send_it_all View Post
leave them off.
ron schenker is offline   Reply With Quote
Old 05-26-2007, 05:29 PM   #5
Exclamation
recess lights
i figure it may be because i did not splice the stranded 16-gauge from the appliance (recess light) to the 14-gauge solid feeder.
the light is brand new.
Old 05-26-2007, 06:36 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
First off, stop calling it a "feeder". This is the completely wrong term and will cause confusion to some folks trying to help. I now see what you are talking about in the other thread.
If you did not splice the wires how is it coming on at all?
Old 05-26-2007, 08:35 PM   #7
i did splice but i thought i did not do a good job. i respliced but to no avail i think there may be something wrong with the switch. i also used a very old scrap cable to go from the swicth to the light so it may be that so i will replace that with a brand new cable.
what should i call the "feeder" ? i appreciate your constructive criticism but it will be even more constructive if you provide a correction
Old 05-26-2007, 08:36 PM   #8
Exclamation
Correction
oops - in my post two posts ago i said that i "did not splice" but i meant to say that "i did not splice WELL ENOUGH".
Old 05-26-2007, 10:13 PM   #9
A feeder would be what feeds a panel. What you are working with is a circuit.
I guess what is confusing is that circuits cab be "fed", or you can work with the "feed" to a circuit. I know it seems like semantics but these are not feeders.
It is entirely possible I am being too picky here, but it is just odd to see the wrong terms.
You are right, I should have provided an alternative before.
OK, describe "flicker".
Literally on and off?
Just dimming slightly?
Does the flickering correspond with anything else?
A (bad) splice will typically either work or not.
Old 05-26-2007, 11:14 PM   #10
it is on and then it goes off for a split second.
Old 05-27-2007, 07:53 AM   #11
What type of light bulbs are you using? What type of switch? I doubt the problem is in your splices.
A service wire comes in from the utility to a meter then from a meter to the main panel. A feeder goes from the main panel to a sub panel, or from one sub panel to the next sub panel. A branch circuit goes from a panel to "outlets". The code definition of an "outlet" is anything that uses electricity. Most standard switches are not outlets because they control electricity they do not use it. Lights and appliances use electricity.
While we are on the topic, a "plug" goes on the end of your appliance cord. A "recepticle" is there in the wall for you to plug the appliance into it.
Master Electrician
Old 05-27-2007, 09:10 AM   #12
Pro
All of the lights in the house?
or
Just 1 circuit? 1 leg?
Does it go off or just dim?
pruane is offline   Reply With Quote
Old 05-27-2007, 12:24 PM   #13
What other items are powered by that circuit? Is something like a refrigerator or AC on that circuit? Anything else with an automatically or thermostatically controlled motor?
When a motor starts up, it draws a lot of current, and particularly for a PC light it might cause it to go off for a second whenever the fridge cycles on for example.
NateHanson is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 06:02 PM
Lights for a garage? stagger19 Electrical 8 01-16-2007 06:58 AM
Upgrading can lights to insulated? juliejules4 Electrical 2 12-03-2006 05:25 PM
Halogen flood lights chicagonyc Electrical 5 07-15-2006 11:11 PM
