Why Do I Get A Buzz When Only One End Of Me Is Connected? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2012, 07:52 PM   #1
Rewards Points: 14
Why do I get a buzz when only one end of me is connected?
Hello. I hope that you are happy and well.
I moved from Western New York State down South, and am living in a rented house. I have a bunch of hi-fi and electric music and recording gear.
Down here whenever I touch anything that is plugged into the ac power, I get a tingle. I don't have to be connected to anything. Rubber-soled sneakers, ugly carpet, touch a mic or a guitar string, tingle. Some of the gear is two-wire, some two-with-ground. No matter. Touch anything, tingle.
It happens with everything down here. It didn't happen with anything back in New York.
I haven't been able to apprehend any explanations of this on the Web.
I can't say that I like it very much. Is there a cure? Especially a cure that I could talk a landlord into going for?
PA
Pizza anyone? is offline   Reply With Quote
Old 10-04-2012, 09:21 PM   #2
Master Electrician
It's most likely a ground issue. You get the same phenomena when guitar amps in houses with no ground. Electronics, especially audio dislikes no ground.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 10-04-2012, 09:42 PM   #3
Rewards Points: 582
PA
see if you can get us a picture of your electric box and maybe some plugs .... may tell us something...ben sr
Old 10-04-2012, 11:19 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,096
PA
Two most likely possables are -
1 - There are some currents flowing in your earth line !
2 - Your system might not be earthed properly, or at all !
Without more details cant say for sure which one,
or it could be a combination of both.
A power outlet tester will tell you if you are earthed properly.
dmxtothemax is offline   Reply With Quote
Old 10-05-2012, 12:02 AM   #5
Rewards Points: 416
I bought my wife a new ( pre - owned ) sewing machine at an auction for 8 bucks that had a 2 prong plug. Beautiful old machine in a nice cabinet. She had the nerve to complain that it was shocking her therefore she couldn't sew a straight stitch.
I measured the volts at about 8 and after conferring with my electrical son was advised to turn the plug over. The volts dropped to half the previous reading and now the seam in the butt of my britches looks better because she couldn't feel 4 volts unless she licked her fingers to thread the needle.
Old 10-05-2012, 12:11 AM   #6
Rewards Points: 258
Ah new insite. Your house doesn't seam to be grounded properly. And your outlets are very out of date if you can turn the plug over and still plug it in
redman88 is offline   Reply With Quote
Old 10-05-2012, 12:16 AM   #7
Rewards Points: 416
It isn't the house out of date but the sewing machine is.
Old 10-05-2012, 07:03 AM   #8
Resi EC
Rewards Points: 252
PA
If we are guessing, I might say 'bootleg ground'.
A 'bootleg ground' is where someone jumped a wire from the neutral (white wire) side of receptacle to the green ground screw.
You could pull a receptacle that is showing grounding and check this.(turn power off first)
Gac66610 is offline   Reply With Quote
The Following User Says Thank You to Gac66610 For This Useful Post:
ben's plumbing (10-05-2012)
Old 10-05-2012, 08:52 AM   #9
Rewards Points: 6,652
When Woodstock happened in 69, they had plenty of problems caused by poor electrical work. Shocks when touching equipment, hums abounded. Listen to some of the old recordings, and you will hear the hums load and clear. One in particular is Jimi Hendrix live at Woodstock. Gives a cool edge to the sound.
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Connected circuit breakers question gsteel1028 Electrical 13 11-30-2011 05:51 PM
New Honeywell thermostat connected to old Climatrol heat pump olorintf HVAC 0 08-24-2010 10:52 AM
An outlet died, how to find out where it is connected and grounding problems Korhan Electrical 3 09-23-2009 06:52 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
