Why Did My Outlet Lose Power? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 12:17 AM   #1
Why did my outlet lose power?
When my contractor tore out the tile in my kitchen he took the outlets out of the box (without disconnecting them). That should not have created a problem. However, I lost power in three outlets on the same wall. Two of them were not touched by the contractor. No breaker was tripped. He checked the panel and all breakers are okay. It is an older house and there are no GFI outlets. He said to hire an electrician to find the problem since he couldn't. Any Suggestions?
chuckr is offline   Reply With Quote
Old 01-26-2011, 12:28 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if there are any joints in the wires in the boxes he pulled the receptacles out, he may have cause the connection to open. I would start with turning off the breaker to those receptacles and remake the joints in the boxes, turn the breaker back on and check.
The Following User Says Thank You to nap For This Useful Post:
chuckr (01-26-2011)
Old 01-26-2011, 09:16 AM   #3
Thanks Nap
I removed the outlet and checked the wire. No power.
Old 01-26-2011, 09:21 AM   #4
Experienced
Jackofall1's Avatar
You have an open circuit, not sure how you are going to ensure the power is off to those circuit touched by the contractor, but what you are going to have to do is wire nut, black to black, white to white, upstream from the recepticles that are no longer powered.
Careful the first black wire in the chain will be hot!
Old 01-26-2011, 09:23 AM   #5
Rewards Points: 120
Do you know for certain which breaker the affected receptacles are on? If not, I would swich all of them off, and back on, one at a time, to be sure that you check the affected circuit. It is not terribly uncommon for a breaker to trip, and still not appear to be fully off.
Old 01-26-2011, 09:34 AM   #6
Rewards Points: 558
Are you sure there arenít any GFI outlets anywhere like out outdoors, garage, bathroom etc. On some rare occasions there are some on the exterior. Some where, one of those GFCI receptacles has tripped. I would start the search in the garage. 90% are there.
epson is offline   Reply With Quote
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 05:38 PM
How to Install Recessed Power Outlet in Floor harlandave Electrical 3 06-19-2010 02:07 AM
Power through outlet to two single pole switches aaronmoon Electrical 2 08-12-2009 08:29 AM
Only one outlet will power treadmill? archer75 Electrical 17 05-05-2009 12:20 AM
distance to a power outlet amakarevic Electrical 4 12-19-2008 06:57 PM
