Why Circuit Breakers Trip Doesn't Trip..?? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 05:14 PM   #1
Why Circuit Breakers Trip doesn't trip..??
I have siemens breaker which was just replaced about two month before. It is fine for two months without problem. Today, power to laundry and garage light including some power plug stop working and found that all they are interconnected to same connection.. I checked in Breaker box... but no of the breaker is tripped. I called the person who replace the pannel but he is not responding me.. Could you please provide me just guidline the area .. could be the problem.. and what will be best way to move on.. appreciated
Bharat_ghimire is offline   Reply With Quote
Old 11-17-2010, 05:31 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Some breakers don't visibly trip. You'll have to turn the breaker off, and then on, and it should be good. If not, then it could be anything from a lose wire or bad breaker. I'd start with turning it off and then back on to see if that works. (kinda like rebooting a computer lol)
Old 11-17-2010, 06:02 PM   #3
I=E/R
a7ecorsair's Avatar
You need to clear up your post - it is too confusing. Did you have the whole panel replaced?
a7ecorsair is offline   Reply With Quote
Old 11-17-2010, 07:35 PM   #4
Rewards Points: 256
I see nothing confusing about that post: clearly indicates panel was replaced.
Most of the time you can't visibly see the tripped one.
Sometimes you can find it by lightly touching the breaker switches. The tripped one will often flip off with little pressure.
If that doesn't work flip them off and on one by one untill you find the winner. Then spend some time to label your panel
michaelcherr is offline   Reply With Quote
Old 11-17-2010, 07:41 PM   #5
" Euro " electrician
frenchelectrican's Avatar
Some breakers are hard to tell if it was tripped postion however there is one more item is check the GFCI receptale to make sure they are not tripped as well.
Merci,
Marc
Old 11-17-2010, 08:21 PM   #6
Rewards Points: 150
Seimens had recall on breakers recently. It involved spring pressure no being able to hold the break points closed. Google it and check the dates.
ianc435 is offline   Reply With Quote
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Tandem Circuit Breakers Huventude Electrical 0 09-22-2010 01:20 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Why do baseboard heaters have 2 circuit breakers? mhaucke Electrical 4 07-08-2007 05:10 PM
Circuit Breakers Unregistered Electrical 4 09-13-2004 08:49 AM
