Why Can't I Figure This Out??? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2009, 09:30 PM   #1
Why can't i figure this out???
Ok, i'll try to make it short (no pun intended ha, i know i'm lame). This house 17 years old, has an outlet and light near the back door, with a switch just inside the door. Well she said that the outlet and light hasn't worked for about 6 years, and she finally called someone out to fix it.
So i found there is no power coming to the area, so went to the basement... and i flipped all of em off and on. Still no power. But it can't be a bad breaker because everything in the house (outlets, appliances etc) work. And there is no specific breaker for this outlet. So what i can deduct is that some where from the panel to the outlet, something has gone wrong. And i don't feel as though a solid 12 gauge could 'break' or a mouse chew it or something like that...
any thoughts would be appreciated.. hope everything makes sense.
Nshihhsieh is offline   Reply With Quote
Old 08-21-2009, 09:39 PM   #2
Loose wire somewhere
Or a sawzall gone bad
Screw thru a wire
No hidden GFCI ?
outlet is inside or out?
Old 08-21-2009, 09:59 PM   #3
Rewards Points: 2,350
So, just so we're clear and I understand the situation, a homeowner has an electrical problem with a light and receptacle and she called you to investigate. Is that correct?
Old 08-22-2009, 12:32 AM   #4
Advice worth 2 cents!
Rewards Points: 150
inphase..that's shrewd! but your right...lady should call an electrician.
_Pete
oh...and to answer the OP's original title......."because you didn't go to trade school"
---pete
HandyPete is offline   Reply With Quote
Old 08-22-2009, 02:04 AM   #5
Inphase.. it was my grandmother
and pete, of course i didn't go to trade school, otherwise i wouldn't be posting on the DIY forum
Old 08-22-2009, 02:26 AM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Ns, Good reply, and welcome to the forum
You are going to have to trace the wiring to the source after first exploring Scuba Dave's points that question any precipitating event that occurred six years ago.
  • Major Repairs?
  • New addition?
  • Big Storms?
  • Plumbing changes?
  • New Installations? (6 years ago)
Keep us informed and we will help
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-22-2009, 03:28 AM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
How did you determine no power comes into the switch or outside light? Use a voltage tester? Did you check in both the fixture box and the switch?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-22-2009, 08:28 AM   #8
Yes, i tested with a multi meter and there is no power coming to anything
and we've added no additions, no remodel etc nothing like that.
So what has stumped me now is, maybe i have a bad breaker and don't know it, but i can't figure out which breaker it goes to because i can't test for power.
And another question, if one gfci outlet trips in the house, that effects all the outlets correct? so i need to find all of them and reset them correct?
thanks
Old 08-22-2009, 08:35 AM   #9
First, check hot to neutral, then hot to ground. Also, check your meter on a known live circuit to make sure it is working. Check power at the nearest receptacle to the problem. Pull it out and inspect the wiring there. Test at the light switch.
Then move to the panel, and test each breaker. I'd recommend turning the main off while removing and installing the panel cover. Do not stand in front of the panel while testing, stand to the side. Ground one tester lead, and move from breaker to breaker making sure you get 120 V at each.
And yes, a GFCI could be the culprit, so test and reset all of them.
Old 08-22-2009, 04:11 PM   #10
Did you check in the outside light fixture junction box for power? I just spent a lot of time with the same problem and found the feed was thru the junction box outside and the neutral was being switched. Someone had changed the light fixture and a burned out bulb stopped all power to the switch and the receptical.
RetiredKeith is offline   Reply With Quote
How to figure out where to start in laying out tile cheryldtrixie Tiling, ceramics, marble 3 06-01-2009 11:49 AM
Please help me figure out this lightbulb! eleazar Electrical 13 05-04-2009 07:50 PM
How does a person figure a bid for sheetrock finish and painting? michell Painting 3 08-11-2008 04:23 PM
I Can't Figure It Out. KTW39 HVAC 2 10-01-2007 07:30 PM
how to figure wrap around porch roof?? What have I done Building & Construction 1 07-24-2006 12:43 AM
