Why? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 10:37 AM   #1
Rewards Points: 164
Why?
Why would this outlet have been used for my sump pump?
ryan50hrl is offline   Reply With Quote
Old 08-27-2012, 10:49 AM   #2
Rewards Points: 812
Why not?
But seriously its hard to say. It looks like someone was reusing some old piece of gear with a fuse holder. I believe current code (2011) is for a individual branch circuit for sump pumps and GFCI protection.
Use one of these to be extra safe.
http://www.legrand.us/passandseymour...x#.UDubwaPedc5
curiousB is offline   Reply With Quote
Old 08-27-2012, 10:55 AM   #3
Rewards Points: 164
my question is why you would use a fuse on a sump pump that's a ready on a circuit breaker system? Is there any reason that would have been done in the past? The outlet was put in within the last five or 10 years so it's not original to the house. If that outlet has failed, which it has, I would not be required to bring it up to GFCI would I? My sump pump hasn't run once in the last two years I've been here, and yes it's been hooked up to a different live circuit. If I'm not required to bring it up to GFCI by replacing the outlet, should I still?
Old 08-27-2012, 11:02 AM   #4
Rewards Points: 130
Maybe they used the fuse as an attempt to provide the required disconnecting means? Just a guess. I have to double check, but I believe you will need a switch along with the GFCI receptacle for the sump pump motor if the breaker is not in direct line of sight.
Old 08-27-2012, 11:08 AM   #5
Licensed electrician
Rewards Points: 1,506
If GFI or AFCI protection would be required in that location during new installations it is required to be installed when a replacement is made. This is one of the few areas that the NEC is retroactive.
A JV, since the cord plug qualifies as a means of disconnect there would be no need for a switch.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
gregzoll (08-27-2012), Speedy Petey (08-27-2012)
Old 08-27-2012, 11:10 AM   #6
Rewards Points: 164
Okay, looks like I'll be heading back to the store to pick up another GFCI.
Old 08-27-2012, 11:16 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
Not true on either count, unless the code specifies a GFI is required for that area.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 08-27-2012, 11:28 AM   #8
If the sump pump is in an unfinished basement or crawlspace, GFI protection would be required.
Old 08-27-2012, 12:24 PM   #9
Rewards Points: 6,652
You will find those also on old whole house fans, furnaces/boilers. Nothing wrong with them. As they say, if it is not broke, do not fix. But nothing is wrong with bringing up to more modern codes. Keep in mind, that you lose the "grandfather" status when updating the various electrical circuits in a structure.
Old 08-27-2012, 12:26 PM   #10
Rewards Points: 164
Something was broke, the outlet doesn't work anymore yet it has voltage to it, installed the new outlet now it works fine
Old 08-27-2012, 01:00 PM   #11
Rewards Points: 812
This is how these fused switches are marketed. Maybe prior owner though he was protecting motor windings.
Old 08-27-2012, 02:47 PM   #12
Did you try replacing the Edison fuse first, before swapping out?
Old 08-27-2012, 03:08 PM   #13
Rewards Points: 164
Sure did,,,,, no luck
