Why Is A 1/2" Knockout 7/8" In Diameter? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2012, 08:09 PM   #1
Rewards Points: 135
Why is a 1/2" knockout 7/8" in diameter?
Silly question, I know.
smata67 is offline   Reply With Quote
Old 05-25-2012, 08:13 PM   #2
Missouri Bound's Avatar
The inside diameter of the typical 1/2" conduit is 1/2". Therefore all fittings which would fit the same size hole as one for 1/2" conduit are refferred to as usable in a 1/2" KO. Why does a nut for a 1/4" bolt measure 7/16"?
Do you want it your way or the right way?
Old 05-25-2012, 08:25 PM   #3
Rewards Points: 12,878
Works the same with all pipe fittings.
Old 05-25-2012, 09:08 PM   #4
Rewards Points: 135
So fittings that screw into the "1/2" knockout end up with 1/2" clear opening. I'll verify tomorrow when I'm back on the job.
Old 05-25-2012, 09:43 PM   #5
It's a "nominal" measurement.
Old 05-26-2012, 08:24 AM   #6
Yes, nominal (named) vs. actual. And a 2x4 is not 2" x 4".
Old 05-26-2012, 12:38 PM   #7
Master Electrician
for anyone interested
http://www.home4c.com/conduit.htm
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
kbsparky (05-26-2012)
diameter size for drapery rod fdf47 Interior Decorating 4 04-14-2011 08:49 AM
Installing bathroom sink - drains off slightly less than pipe diameter lazzlazz Plumbing 17 05-21-2010 06:12 PM
1/2" diameter hole in hollow core door noahweb Carpentry 4 02-16-2010 09:36 PM
Duct Diameter Reduction Earnie HVAC 4 01-27-2010 03:52 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
