#1 |
Whole house surge protectors
Due to severe winter storms in early 2011 and hurricane Irene, there were quite a few folks in my area (NW NJ) that experienced surges. I'd like to get one for my house. From what I can tell, the type 2 installation (SPD is installed in breaker panel) is similar to installing a new circuit breaker. That would be my way to go as I have installed 3 of those in my house.
I've seen two different models: 1) external (to the panel) model that ties into two existing breakers -and- http://www.amazon.com/gp/product/B00...pf_rd_i=507846 2) internal model that actually clamps into the panel like a double pole breaker: http://www.amazon.com/Siemens-QSA151...l_mb_hu_m_2_dp Is there an advantage of one over the other? Any specific models you recommend? |
#2 |
Average Joe/ex-Navy IC3
This topic comes up all of the time on here. Do a search and you will find that your answer is already out there.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#3 |
Electrical Contractor
The external ones can be used on almost any panel but the internal ones that go in like a breaker have to be rated for your panel. We had a Siemens model in our Siemens panel and it worked great I have to get a replacement because our generator regulator failed and one leg was doing way over 120 and fried it. It would have probably still been in there if it was not for that.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe. |
#4 |
You make a good point. I didn't take into consideration that the internal ones had to match my panel. Not many choices in my area.
#5 |
Matching or being listed for use in your panel. A supply house in your area may be able to help you with some solutions.
| Display Modes | |
| Connecting main house to guest house... | hlavine | Building & Construction | 31 | 03-28-2012 10:04 AM |
| Big water leak under house | Puzzles | Plumbing | 4 | 04-27-2011 03:50 PM |
| Trane XR12 1.5 ton-Too small for my house? | Badfish740 | HVAC | 7 | 09-23-2009 06:48 AM |
| Surge protectors | geno2 | Electrical | 34 | 03-31-2009 09:15 AM |
| Whole house surge protector? | 4thtbird | Electrical | 2 | 02-04-2008 08:19 PM |
