Whole House Surge Protector - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 11:37 AM   #1
Rewards Points: 27
Whole house surge protector
I have a 400 amp service. I thinks it's really just 2, 200 amp services run to 2 separate panels. There are 2 separate shut offs outside, but just 1 meter. I also have a 100 amp generator panel fed from the second 200 amp panel. Can I use just one whole house surge protector or do I need one for each 200 amp panel. There is plenty of room in the 200 amp panels, but the 100 amp generator panel is full.
Thanks again for the help.
jodywoj is offline   Reply With Quote
Old 10-04-2009, 07:25 AM   #2
Remodeling Contractor
if rated for the 400 amp then you can use one surge protector. Panasonic makes a good one for this job.
Old 10-04-2009, 10:34 AM   #3
If you are in FL you need pretty hefty protection.
Old 10-04-2009, 11:39 AM   #4
Licensed electrician
Rewards Points: 1,242
If you have 2 panels you would need one for each panel.
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
Whole house surge suppression question WoodworkerDave Electrical 4 10-02-2008 01:26 AM
Re-siding house jdig Building & Construction 5 04-10-2007 10:15 AM
