Whole House Surge Addon - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 11:35 AM   #1
Trucon01's Avatar
Rewards Points: 510
Whole House Surge addon
Hi everyone,
I'm about to have my old 200a panel swapped for a new Square D QO box / breakers. I won't have the CHSPT2ULTRA whole house surge when the electrician comes and was wondering if this was something I could do myself?
I won't have it because they want to charge me 500.00 for this when you can get them for 122 on ebay (NEW).
Also, the master electrician said he would charge 800.00 for the panel, 50 extra for 2 grounding rods and 125 for the permit, taking roughly 4 hours. I will be supplying all equipment.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 11-05-2012, 12:15 PM   #2
Rewards Points: 6,652
Every area is different, and every situation opens a can of worms. Really no way anyone can tell you why their job is different than what it would be elsewhere.
As for the whole house, yes it is good insurance. Also adding a transfer switch if you use a generator is also a good idea.
Old 11-05-2012, 12:31 PM   #3
Trucon01's Avatar
Rewards Points: 510
I was just posting the details of the work I'm having done for any readers with similar projects.
As for the surge, it doesn't look like it would be tough for me to do. Looks like I just get a 50a double pole breaker, attach the surge to that, neutral bar and ground. Done
Old 11-05-2012, 12:45 PM   #4
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
You are correct on connecting the surge protector. It's easy. Turn off the main and be careful of the main lugs while you work.
The money you mentioned for the electrician sounds reasonable.
John
jrclen is offline   Reply With Quote
Old 11-05-2012, 02:55 PM   #5
It is actually either a 15 or 20 amp breaker per leg.
Old 11-05-2012, 03:08 PM   #6
Trucon01's Avatar
Rewards Points: 510
For the Micro and Max they want you to use 15-20. In the manual for the ULTRA it says to get the most out of the unit to use a double pole 50.
The Following User Says Thank You to Trucon01 For This Useful Post:
jagrrr (11-07-2012)
House gets too Hot at night furthermore HVAC 14 09-22-2015 11:09 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
Whole house surge protector? 4thtbird Electrical 2 02-04-2008 07:19 PM
