Whole House Standby Generator - Generac Vs. Milbank - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 11:35 AM   #1
Whole house standby generator - Generac vs. Milbank
Hi everybody. First-time poster here.
Am planning to install a whole-house standby generator for our new home in NW Ohio. Am the last residence on the service line and am fearing long-term outages. During construction we installed an automatic switch on the feed side of our 200A service, so we're 'set' from that standpoint. After reviewing generator costs and our load calculation, I've decided to install a 20kW natural gas generator, but am undecided on a manufacturer. My most local electrical supply house and contractor (sister companies) recommends Milbank generators (model MG20003). The next supplier and installer I trust recommends Generac (Model 5875). Does anyone have any opinions / experience with either of these models?
Thanks in advance for your input!
nwohioguy74 is offline   Reply With Quote
Old 01-27-2013, 11:45 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
I have never heard of Milband gensets. I can't imagine they make their own. Just like Eaton's were re-badged Generacs.
If you have an auto switch your best bet is to stay with that brand. This is something you should have thought about when you bought the switch.
What brand is it?
Old 01-27-2013, 11:54 AM   #3
Missouri Bound's Avatar
I have a Generac LP 7kw which I installed 3 years ago. I did use their 100A panel, which was supplied with the generator. Absolutely no problems. It runs once a week as an "exercise" and has worked flawlessly during outages, at least 6 in the last 3 years. It comes on in less than one minute and when it shuts off there is no power interruption.
Do you want it your way or the right way?
Old 01-27-2013, 11:55 AM   #4
Milbank does manufacturer their own. Here's their website : www.milbankpowergen.com/
The switch was manufactued by Generac. Though technically I see no reason the generator must match the auto switch.
Old 01-27-2013, 12:01 PM   #5
Well, it seems the Milbank is a joint effort with Briggs and Stratton, just like the old Cutler-Hammer/Briggs units. I have had too many problems (with previous Cutler units) and have heard a few issues with the newer units that personally I would never get a B&S unit.
You have a Generac switch, Generac are fine units. I see no reason not to go with a Generac.
And no, the transfer switches are not typically universal.
The Following User Says Thank You to Speedy Petey For This Useful Post:
brric (01-27-2013)
Old 02-02-2013, 12:46 PM   #6
, they have a disclaimer that says other transfer switches may not be compatible.
My installer would only install the transfer switch that Generac recommended for that generator.
fdcapt50 is offline   Reply With Quote
The Following User Says Thank You to fdcapt50 For This Useful Post:
Speedy Petey (02-02-2013)
Old 02-02-2013, 01:25 PM   #7
747
registered
747's Avatar
Rewards Points: 534
Listen to speedy
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
Old 02-03-2013, 01:13 AM   #8
" Euro " electrician
frenchelectrican's Avatar
Even over here in France we do have simauir issue as well when few peoples buy a new standby units and the issue is the transfer switch not all are compareable at all.
There are some specfic models of transfer switch will work properly with specfic generatours.
Merci,
Marc
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 03:54 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 10:39 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 11:01 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
