Whole-house Generator: How Close To House? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 10:22 PM   #1
Robi
Whole-house generator: How close to house?
What does code say about installing an Natural Gas whole-house standby generator next to the house? In particular, what does code say about the generator's exhaust and, say, distance to windows?
Robi.1014 is offline   Reply With Quote
Old 05-24-2012, 10:26 PM   #2
Rewards Points: 6,652
Depends on your AHJ. Everyone's codes are different. Here the placement is no different than if you are placing a air conditioner unit for hvac outside the home/structure.
Old 05-24-2012, 11:15 PM   #3
" Euro " electrician
frenchelectrican's Avatar
The answer will varies a little depending on the Inspector say for the area where it will be used.
However a common sense that no exhaust ports will be near at the window ( most will spec minum of 3 feet )
For how far away from the house it will varies a bit but some states are saying it have to be minum 18 inches away ( this part you will have to check the inspector and manufacter speces for details )
The other thing it will get ya is the natural gaz piping size you may have to change it as well plus upsizeing the meter depending on what the gaz compaine have it setup now.
Merci,
Marc
Old 05-25-2012, 06:33 AM   #4
Rewards Points: 13,446
http://www2.iccsafe.org/states/Virgi..._Frameset.html
Speedy Petey (05-25-2012)
Old 05-25-2012, 07:14 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
This is a building code issue, not an electric code.
Old 05-25-2012, 07:21 AM   #6
In VA your going to need a permit to install it anyway so ask them while your in there getting the permit.
You really should have the gas company do the gas hook up for you. Any gas company can also tell you where it needs to be. All there installers are required to have a code book in the service vehicle.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Large old tree close to house WillK Building & Construction 8 07-23-2011 08:40 PM
Considering buying a house that needs regrading HELP Dr.JUSC Landscaping & Lawn Care 9 06-16-2011 10:58 AM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
