-   -   Who manufactures Utilitech Recessed Lights? (http://www.diychatroom.com/f18/who-manufactures-utilitech-recessed-lights-189099/)
alumiu90 10-23-2013 10:06 AM
I recently had a contractor remodel my basement and he used Utilitech 6" Recessed Lights that he purchased from Lowes. I am not happy with the trim kits and want to replace them, but not sure what other brand trim styles I can use like Halo, Juno, All-Pro by Cooper Lighting, etc.
The model number of the can is #Y301ICWW.
Does anyone know who makes this recessed light for Lowes? I have heard that it is Halo and I have heard that it is Juno. If it is one of these manufacturers can you also advise which model number it is equivalent too.
Oso954 10-23-2013 12:50 PM
Pull the trim from one of the cans and shine a light up into it. There should be a tag in the can listing the trim numbers that are to be used with it.
The tag should also list the model number of the can, which I believe is Y7ICAT. The number you listed is for a 6 pack containing both cans and trims.
alumiu90 10-23-2013 02:54 PM
Thanks OSO954.
If that truly is the number in the can, which I will check tonight, it tells me it is a Halo or Cooper Industries produced product as that would be their series number.
Halo sells it as H7ICT and H71CAT (for air tite). That would help a lot as then I could probably use Halo or All-Pro trims without any issues.
Oso954 10-23-2013 04:08 PM
The issue would be no UL listing for the Halo trims used with the Utilitech cans. No UL listing would be an NEC violation.
alumiu90 10-23-2013 04:36 PM
Why no UL listing when all we are talking about is a metal baffle which would be mated with a housing made by that manufacturer regardless of how they are selling it. So my concern would be fire?
Oso954 10-23-2013 04:57 PM
You are assuming they are made by Halo. They could be a knockoff made in China.
Halo does not certify/list all of their 6 inch trims to work on all of their 6 inch cans. You can have overheating problems because you used a trim and bulb recommended for a non-IC can with an ICAT.
You can always call Cooper/Halo to get their opinion.
TarheelTerp 10-23-2013 06:23 PM
1) Call Lowes
2) Never call that contractor again.
ktkelly 10-24-2013 07:30 PM
I'm using the Utilitech IC housings (UL listed) with Halo trims (also UL listed) and have no problems with them...
