Who Foots The Bill? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 11:45 AM   #1
Who foots the bill?
We hired a licensed electrician to put in a new meter to the house. He got the permits and did neat looking work and the permit passed. The bill included hitching up with the power company. We paid the bill just after the building inspector passed it but before the power company hitched it up. HOWEVER, The power company was not satisfied and says the mast has to be considerably higher. Apparently this means repeating his work and using more wire. Who pays for this screw-up?
dajudem is offline   Reply With Quote
Old 02-10-2013, 12:04 PM   #2
Master Electrician
Rewards Points: 3,756
IMO the contractor pays.
brric is offline   Reply With Quote
The Following 3 Users Say Thank You to brric For This Useful Post:
HIVOLT (02-10-2013), jbfan (02-10-2013), stickboy1375 (02-13-2013)
Old 02-10-2013, 12:23 PM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I find I always have to meet with the POCO because the requirements they write in their rules are bare min and sometimes even though it passes they won't connect it if they feel it is not high enough for your situation.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-10-2013, 12:36 PM   #4
Thank you, I thought so too. His bill included power company hookup but what if he refuses to fix without more cash? Would it be reasonable for me to foot some of it as well? Will I have to file a complaint somewhere if he does not want to fix it? The electrician should probably have had the power company look at it first before deciding for himself how tall it ought to be?
Old 02-10-2013, 12:40 PM   #5
MarginallyQualified
Rewards Points: 2,464
No. It's ALL on him. Hold the line.
For future reference... never pay the whole bill until the whole job is done.
You should investigate WHO to complain to today...
and KNOW what agency to mention if it's needed.
Start by telling the contractor you expect him to "make it right"
by X date certain. If he fails to... then go from there.
The Following User Says Thank You to TarheelTerp For This Useful Post:
dajudem (02-11-2013)
Old 02-10-2013, 12:47 PM   #6
Thanks so much for your answers. Tarheel, I particularly appreciate your admonition to never pay until done. I thought it had passed inspection so was good to go... I am old to learn but I will not forget your good advice! I will follow your instructions to a "T".
Thanks so much, all of you. You have eased my mind.
Old 02-10-2013, 12:50 PM   #7
rrolleston's Avatar
I would make sure you be nice and give him a chance to fix it and make it right. If he went by code and it passed it then just see what he will do. Maybe it could be just a simple misunderstanding between the linemen and the inspector. Bad mouthing the electrician and causing him problems can only make things worse. First give him a chance to make it right.
The Following User Says Thank You to rrolleston For This Useful Post:
oh'mike (02-11-2013)
Old 02-10-2013, 12:51 PM   #8
Yep, you paid for Hooked Up, not anything less and I hope you have that writing.
64pvolvo1800 is offline   Reply With Quote
Old 02-10-2013, 12:54 PM   #9
Civil Engineer
Rewards Points: 4,568
This is a very difficult question, more suited to a legal forum. For one thing, you have not discussed exactly what contract you had with the electrician. He is only obligated to do the work set forth in your signed contract, so if your contract calls for him to pull the permit, install the meter, and have it pass inspection, he likely did exactly what he was required to do.
The fact that the POCO had additional requirements beyond the permit is unfortunate, and if your contract required the contractor to coordinate with the POCO, then of course he would have been obligated to do so. But if your contract fails to mention coordination with the POCO, then it is a tricky question as to whether the electrician was obligated to contact the POCO and meet their standards.
It is certainly reasonable for you to ask the electrician to finish the job per POCO requirements at no additional cost, but if he refuses, this becomes a tough question in my book.
Old 02-10-2013, 12:58 PM   #10
Lic Elect/Inspector/CPO
Where are you located?
It is the contractors responsibilty. The contractor should know the requirements for the POCO. I agrre that you should give the contractor a cahnce to rectify the issue. As stated in another post it may just be a miss undestanding. Most POCO have thier installation requirements online, so you could possible look it up.
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
HIVOLT (02-10-2013)
Old 02-10-2013, 01:02 PM   #11
jbfan's Avatar
Rewards Points: 240
Give the inspector and the poco a call.
Sometimes they have to fight it out among themselves.
I would have a poco engineer come out and look at it again.
jbfan is online now   Reply With Quote
Old 02-10-2013, 01:26 PM   #12
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm going to be on the other side of the fence...sort of.
The NEC has guidelines as to how high overhead service drops have to be. The electrician has to abide by these, but the inspector should be able to see any potential problems with these clearances.
With that said, every POCO I have know of publishes a manual for services. My POCO has a section for residential masts. These requirements are not in the NEC.
I have heard about some crazy requirements from the POCO above and beyond anything in their manual or was is usual. IF the installation was done according to the NEC, which I assume it was judging by it passing inspection, and it was done according to your POCO's metering manual, then this has to be on you. There is no way for a contractor to know about some sort of above and beyond requirement from your POCO.
Who is your power company?
How far does the mast extend above the roof?
Are there any structures directly below the service drop?
Is the area below the drop subject to vehicle traffic?
We could possibly determine if this was the contractors oversight, or one of those above and beyond situations if you can provide answers to the above questions.
As for the payment, alot of EC's around here require payment when the job is done, not when it is inspected, and definitely not when the POCO makes its final connections. The problem is that there are too many ways for customers to try to weasel out of paying. They put off scheduling inspections. They say they aren't satisfied often requesting work outside the scope of the contract. Add to that, the only way to have the POCO hook up permanently is the inspector has to call the POCO after the permit has been closed. Then they will come out when it suits them. I have had service changes go up to 4 years without permanent hook up. Your situation might be the exact reason we require payment at the time we do. We do put all this in our contract and explain to the customer, so there are no surprises.
Old 02-10-2013, 01:28 PM   #13
MarginallyQualified
Originally Posted by jbfan View Post
Give the inspector and the poco a call. NO!
The only call the customer should be making aside to their EC...
is to the States Attorney or Licensing Board.
As the EC you c/should do that too.
Bottom line though... it's YOUR job. Make it right.
Old 02-10-2013, 01:31 PM   #14
k_buz's Avatar
To say this without knowing anything more that what the OP has stated tells me you haven't worked with POCO's very often.
The Following 3 Users Say Thank You to k_buz For This Useful Post:
ddawg16 (02-11-2013), jbfan (02-10-2013), Speedy Petey (02-11-2013)
Old 02-10-2013, 01:38 PM   #15
jbfan's Avatar
Rewards Points: 240
The way it works here, I finish the job, call for inspection, inspector calls poco for hook up.
The only time I meet with the poco is on some unusual installations.
Tags
electrical error
Upgrade Svc., Overhead; Bill vs. Estimate Question Rpsjr Electrical 6 04-22-2012 04:15 AM
Groundhog named Bill Murray Angela3511 Pest Control 5 04-18-2011 08:20 PM
Advice Requested on handy-man bill just received 2031pratt Off Topic 15 08-16-2010 04:01 PM
High electric Bill? HautingLu General DIY Discussions 9 08-28-2009 01:39 PM
Help! Electric bill too high, what can I do? pirategirl007 Electrical 24 01-19-2009 11:35 AM
