White Wire To Ground? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2014, 09:30 PM   #1
Rewards Points: 280
White wire to ground?
I have an average home wiring, 14/2 w G setup. There are three romex cables going into a box with 2 switches. There is a hot cable coming in, 2 switches and 2 cables exiting, to separate ceiling lights.
Everything seems normal except one white wire from a ceiling light is connected to the bare ground wires. It appears this is the original wiring (25 years old) and has not been tampered with.
The other 2 white wires are wire nutted together.
IS there some highly technical reason a white wire would be connected to the ground?? Did I give enough info?
Jim
jjrbus is offline   Reply With Quote
Old 02-06-2014, 09:38 PM   #2
Licensed electrician
Rewards Points: 1,876
The white should not be connected to the grounding conductors. This can create a shock hazard. A neutral may have been lost and this was an attempt to get the light to work again.
The Following 5 Users Say Thank You to Jim Port For This Useful Post:
Kpack (02-07-2014), mpoulton (02-08-2014), plummen (02-07-2014), stickboy1375 (02-06-2014), Stubbie (02-07-2014)
Old 02-07-2014, 12:12 AM   #3
Rewards Points: 280
Thanks for the response. If the neutral was lost and I disconnect the white wire from the ground, the light will not work?
I now see that this wire use to feed 2 ceiling lights and now it is one light if that means anything?
Any input or suggestions greatly appreciated. Jim
Old 02-07-2014, 12:30 AM   #4
Rewards Points: 512
Turn the circuit off and remove the white from the bare - put a wire nut on the white (temporarily), or at least get it out of the way from touching anything. Turn circuit back on, and post back with results.
Installation is the Reverse of Removal.
Old 02-07-2014, 08:43 AM   #5
Rewards Points: 280
Disconnecting the white wire causes one light not to work.
JIm
Old 02-07-2014, 08:50 AM   #6
Try connecting the white you just disconnected to the other whites.
A complete circuit needs two wires to operate.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
plummen (02-07-2014), sirsparksalot (02-07-2014), Stubbie (02-07-2014)
Old 02-07-2014, 10:57 AM   #7
Rewards Points: 280
Connecting the white wire to the other two white wires causes the light to come on. I see no smoke or sparks anywhere and the breaker did not trip!
JIm
The Following User Says Thank You to jjrbus For This Useful Post:
Old 02-07-2014, 02:16 PM   #8
Rewards Points: 512
If not already done, the ground wires should have a pigtail to each switch.
Old 02-07-2014, 03:41 PM   #9
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Be carefull isolating neutral wires if you cant verify the rest of the circuit, its really easy to cause a power surge to electronic equipment that may be plugged in to that circuit if theres no neutral.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-07-2014, 05:44 PM   #10
Rewards Points: 280
Thanks for the responses, always appreciated. Because the ceiling light was changed from 2 to 1 this has me concerned so I will attempt to visually inspect the wire in the morning. It runs through a vaulted ceiling space, not designed for a senior to navigate through.
As long as I have your attention, there is a lot on this circuit, it is 14/2 wg and protected by a 15 amp breaker. There are 3 switched interior ceiling lights, 2 with fans. 1 small switched florescent light. 3 interior duplex outlets. 3 switched exterior lights and 1 exterior duplex outlet. Seems excessive?
JIm
Old 02-07-2014, 06:31 PM   #11
plummen's Avatar
JIm
Ive seen complete older houses run off of 3-4 15a screw in fuses in the
past. Hahaha
Normally I try and run a seperate circuit for each room except kitchens and garages on new construction/remodel work, I do it more for ease of future repairs myself.
Old 02-07-2014, 06:47 PM   #12
Rewards Points: 280
The good old days, when electrical problems were solved with a penny
Old 02-07-2014, 08:02 PM   #13
plummen's Avatar
Pennys under fuses and light bulbs, if I had a dollar for eveytime ive yanked out a piece of copper water line with ends smashed down used in place of a cartridge fuse in a disconect! Hahaha
Old 02-07-2014, 08:41 PM   #14
Doesn't seem excessive at all. Many homes have much more that that.
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 09:51 AM
Trying to figure out my bathroom wiring. May not have ground wire. pman6 Electrical 12 04-15-2013 07:50 PM
Ground wire becomes neutral blazo Electrical 11 03-09-2012 08:20 PM
Ground rod and ground wire question mulltron Electrical 17 07-29-2011 05:10 PM
neutral wire became ground? okedomantakeshi Electrical 18 12-29-2009 03:18 AM
