Whirlpool Tub Gfci - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2009, 07:34 PM   #1
whirlpool tub gfci
Quick question:
I know the tub needs a dedicated 20amp gfci circuit. However does the recipticle need to be gfci or the breaker or both?
thanks!
jeerme is offline   Reply With Quote
Old 03-03-2009, 08:03 PM   #2
Rewards Points: 150
Send a message via AIM to Bocolo
I am no expert, others will chime in soon. I think you can have it either way, although some people prefer to have it at the receptacle. That way if it trips for any reason you can reset it right there instead of having to go to the service panel.
Bocolo is offline   Reply With Quote
Old 03-03-2009, 08:03 PM   #3
You can provide gfci protection both ways, but you don't need both on the circuit. Usually the receptacles are a little cheaper to purchase, plus you could reset it without going back to the panel.
Plumbvoltage is offline   Reply With Quote
Old 03-03-2009, 08:30 PM   #4
Plus changing it out for troubleshooting is easier.
Old 03-04-2009, 12:41 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Just becarefull some local codes may get little strict on this matter so check with your local codes on this one.
Normally what I useally do when I bring in new circuit for whrilpool tub typically my SOP is bring two circuits { trust me on this one } the reason why I do that due you have one circuit for pump motor side and second circuit for electric heater and also mount the faceless GFCI receptale on the wall away from the tub and below the tub use the standard receptale the reason why I do that because if the GFCI tripped you have to open the tub access panel to order to reset it.
Merci,Marc
Old 03-04-2009, 11:20 AM   #6
thanks guys!
Old 03-04-2009, 11:43 AM   #7
Rewards Points: 204
Is this tub inside or outside. Is it on grade or above grade. Working with pools and spas is not the same as installing a new light fixture. Unless you are familiar with Article 680 of the NEC, get a qualified electrician on this one friend. This is a life or death install. You choose.
Old 03-04-2009, 01:37 PM   #8
Rewards Points: 156
I assume the OP meant a whirlpool tub for a bathroom and not a dedicated "hot tub"
I chose to use the GFCI breaker instead of an outlet because I didn't want to have to be messing around underneath the tub, through the access panel trying to figure out if the GFCI was tripped. Very easy to tell from the breaker panel. But, to each his own.
I did this for both the heater and the motor circuit.
moondawg is offline   Reply With Quote
Old 03-04-2009, 02:46 PM   #9
yes, this is for an indoor bathtub bathroom installation. I will have an access panel as well. Thanks for the responses!
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
