Whirlpool Tub & Electricity - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 01:56 PM   #1
Rewards Points: 87
Hi Everyone,
I don't know if I'm a victim of Murphy's Law, or if I'm doing something wrong.
I installed a whirlpool tub and am now working on the electric side of things. The tub came with a motor and I added the heater accessory. Directions said to install seperate outlets with GFCI protection for the pump and heater.
Here's my setup. I have two 15A GFCI breakers in my panel on seperate busses. Black wire is run to upper breaker, red to lower. White wire is run to upper breaker, with a pigtail to the lower. Both pigtails from breakers are tied into the neutral bus.
I've run 12/3 with ground to the tub. I installed one commercial grade outlet. I broke off the tab connecting the two hot side screws. Black went to upper, red to lower. White is connected to neutral, ground to ground.
PS - There is nothing plugged into the outlet, and this is the only outlet on the circuit.
Now, here's my problem. I bought the two breakers at the same time. One works, the other doesn't. It stays in the tripped position. I swapped wires. I moved the breakers. The non working one stayed non working while the working one works on both hot lines, in both slots.
So, I figure the breaker is defective. I exchange it. Same problem with new one. No matter what position, it will not reset.
Please help.
Thanks,
Tim
myowneq is offline   Reply With Quote
Old 11-13-2012, 01:59 PM   #2
Licensed electrician
Rewards Points: 1,872
You installed two GFI breakers for the tub using a shared neutral?
Old 11-13-2012, 02:04 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Not going to work.
You need a double pole gfci breaker to make this work.
Old 11-13-2012, 02:10 PM   #4
Rewards Points: 87
Yes, shared neutral for both.
I'm getting the feeling I can't do a shared neutral for two different breakers. Can I do that with the double pole?
Old 11-13-2012, 02:19 PM   #5
jbfan's Avatar
Rewards Points: 650
Yes, that should work.
Old 11-13-2012, 03:16 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,990
Exactly. GFCI's work by sensing the difference in current between the hot and neutral conductors. So if current flows out on the hot conductor and does not return through the neutral, it trips. That's how it detects ground faults. The way you have it set up, all current leaving one breaker returns through the other. It will trip instantly. You need either two separate neutral runs (too late for that now), or a double pole GFCI breaker that senses the net current balance on BOTH hots plus the neutral.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 11-13-2012, 03:23 PM   #7
Rewards Points: 87
Thanks for the help everyone. I might have figured that one out myself, if not for the fact that two different breakers, even by themselves with the known good breaker completely removed, wouldn't work.
However, finding such a 2 pole breaker is not proving easy. Three different electrical supply companies do not carry them in stock.
Old 11-13-2012, 03:52 PM   #8
They are hard to find and quite expensive. I would be surprised if no supply house in your area has one though. But you might get a better price online.
Old 11-13-2012, 03:55 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Last time I checked online for a 2P 20 GFI breaker it was about 80 bucks. You'd almost be better replacing the split duplex receptacle with two separate GFI receptacles and using one regular 2P breaker.
Replace My Whirlpool Water Heater with Which Brand? hermes Plumbing 6 03-17-2012 09:42 PM
What requires electricity? pcampbell HVAC 3 11-05-2011 11:39 AM
No electricity in half the room (somewhat complicated) jimbob8690 Electrical 1 07-13-2010 03:23 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 09:12 AM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 07:42 AM
