Whirlpool Oven Igniter - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 07:54 AM   #1
Whirlpool oven igniter
Oven lights the igniter keeps clicking and oven goes out.i do apartment maintenance so i can exchange parts with other ranges and i have changed the igniter ,spark board, and control panel and i still have the same problem . Broiler and range top work fine
JIM FLYNN is offline   Reply With Quote
Old 11-15-2012, 09:16 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,258
There is a sensor that indicates the oven burner flame has been established. Sounds like a bad sensor.
Coastal South Carolina
Old 11-15-2012, 09:56 AM   #3
Rewards Points: 150
Or perhaps just a dirty sensor. You should be able to remove the sensor and clean the lens.
Dave632 is offline   Reply With Quote
Old 11-16-2012, 07:19 AM   #4
Thanks for the reply but in this case the igniter works as the sensor as well. After giving it some thought I changed the igniter wire and problem solved.
The Following User Says Thank You to JIM FLYNN For This Useful Post:
Dave632 (11-16-2012)
whirlpool oven doesnt heat evenly hsjcrew Appliances 1 12-12-2011 05:32 AM
whirlpool oven temperature setting garis Appliances 5 02-04-2011 02:30 PM
Whirlpool Oven Element Cultcab Appliances 5 01-04-2011 08:21 PM
whirlpool oven problem ElectricianJeff Appliances 0 09-27-2010 04:41 AM
Whirlpool Build In Oven jogan Appliances 0 12-02-2009 06:50 PM
