Whirlpool Energy Saver Water Heater Problem - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 02-03-2011, 05:38 AM   #31
Seasoned DIYer
Rewards Points: 150
There are two types of boards.
http://www.americanwaterheater.com/s.../guides/es.pdf
Both types use four N.O. relays.
Each incoming line has its own relay. One of the relay switches common side.
Other side powers the switched side of heaters.
The two line side relays must be closed for heater to work.
Switched side of each heating element has its own relay.
Relay 1 & 2 are always closed.
Relay 1 connects one of the poles to common side of heating elements.
Relay 2 powers switched side.
Relay 3 controls upper
Relay 4 controls lower
So, for proper operation it's always 1,2 and 3 OR 1,2 and 4.
Each element must go through three relays in series so if a relay becomes stuck on, it won't go into run-away conditions.
If 3 or 4 welds closed and control calls for other element to activate, it should cause the board to see both elements energized and trip on error.
The line side relays serve no purpose other than safety redundancy.
The relays are electronically controlled by computerized circuits based on feedback from elements(which is how it detects failed element) and thermistors.
The electronics is covered, but not completely potted in epoxy so it won't be easy to replace parts even if you could locate problems at component level.
HVAC_NW is offline   Reply With Quote
The Following User Says Thank You to HVAC_NW For This Useful Post:
agtnew7 (12-16-2014)
Old 02-04-2011, 08:05 AM   #32
Originally Posted by earcuffs View Post
"They" sent a free new control board w/ free shipping?
Who, Lowes or Whirlpool? I'll be searching the Lowes stores for a replacement as mine failed. Curious if the new policy is a free board + free shipping. Seems like I would need a backup control board if the replacement can be expected to fail as well. Horrible service history on the electronics for this unit.
Whirlpool sent it to me. I called the 800 number in the book and spoke to a nice, Indian guy, and a few days later the new board came.
Pistol Pete is offline   Reply With Quote
Old 10-27-2012, 09:36 AM   #33
Rewards Points: 528
I have one also.But the lights are all out yet i get hot water daily.Is this the circuit board or what?
hidden1 is offline   Reply With Quote
Old 03-12-2013, 09:05 PM   #34
Whirlpool Energy Smart Water Heater
My water heater worked well for several years (lifetime warranty) but now has begun to either produce lukewarm water or dangerously hot water! The control box on top the heater had wires that burned the paper wiring diagram off the inside of the cover and even partially melted the cover. Whirlpool quickly sent me a new control circuit board but it has been installed and is right now overheating and I am catching the scalding water in a 5-gallon bucket. (Actually, this is the 2nd one they sent me in a week but still no improvement). There doesn't seem to be anything wrong--it just continues to overheat and does the 2-flash high temperature warning. In its defense, it worked fine for about 10 years--still no leaky tank, but seems to be unfixable.
water2coldorHot is offline   Reply With Quote
Old 09-26-2013, 08:13 AM   #35
Wink
We have the Energy Smart electric heater, lifetime warranty. The heater is nine years old and the control board is on the fritz. I called the 800 number, answered a few questions and they're overnighting a new board today. The tech was most helpful and couldn't have been more pleasant. And they comped the overnight charges. I'm a satisfied owner! Now to go heat some water on the stove to shave.
slcullen is offline   Reply With Quote
Old 06-07-2014, 08:18 PM   #36
Whirlpool 50 gl Energy Smart water heater
We have a Whirlpool 50 gallon Energy Smart water heater which is almost 12 years old. It has been working great until recently. We were getting 5 blinking lights on the controller box indicating a problem with the lower heating element. We called customer service and were connected to an American service tech immediately. She was extremely helpful and told us the parts we needed were under lifetime warranty. She shipped the control board, junction box cover and both heating elements and we received them in 2 days. Our only charge was $10 for shipping. We couldn't believe their excellent service after reading so many negative posts. I say without hesitation that they have wonderful service now and I would certainly not hesitate to buy another Whirlpool hot water heater.
Sy T.J.
Sy Tj is offline   Reply With Quote
Old 11-15-2014, 10:10 AM   #37
Rewards Points: 2
Satified customer
I have the 80 gallon Energy smart electric water heater. The water one day became excessively hot. I reset the switch to no avail. First I replaced both elements. Two weeks later I experienced the same problem. I contacted the Whirlpool technical support line and they were polite and helpful. They told me I needed to replace the control board. Yes I had to replace both elements and a control board but they sent the board to me overnight for free. To replace the elements I had to take the old ones to Lowes and they gave me free replacements. I have a lifetime warranty so why would I change water heaters or complain. For the person who is not the original owner stop whining and pay the $75.00.
BobR7867 is offline   Reply With Quote
Old 12-02-2014, 10:31 AM   #38
Rewards Points: 2
I have a Whirlpool Energy Smart electric water heater. I received a 3 flash signal for the heating elements. I replaced both heating elements. After power was restored, the signal flash changed to 2 flashes immediately for high temperature. Impossible since it was just turned back on and filled with cold water. I replaced the board with a new one that was overnighted to me. Now it either flashed 2 or 3 times depending on its mood. Tech support has been very nice about giving me free parts. I have no money for a technician to look at it though. Any suggestions on what it could be now? Please help!
Lpa42933 is offline   Reply With Quote
Old 12-16-2014, 08:32 AM   #39
Rewards Points: 8
Just to add to this situation/I just called the # and the board is on the way. I spoke to a nice lady named Amanda. Thanks DIYers.
agtnew7 is offline   Reply With Quote
Old 02-14-2015, 01:56 PM   #40
Rewards Points: 2
ok I have this water heater. Mine keeps kicking the breaker. Is it still the board that is causing the problem?
oldbiker16 is offline   Reply With Quote
Old 02-15-2015, 01:00 AM   #41
Rewards Points: 8
agtnew7
Just went through the same issue, My problem was the bottom element was bad. This was indicated by two flashes. The previous issue I had was similar but the board was bad. I called the # and they replaced it the next day.
Old 02-15-2015, 01:02 AM   #42
Rewards Points: 8
R you getting any diagnostic flashes?
Old 06-27-2015, 06:22 PM   #43
Rewards Points: 2
Thumbs up
We have been having issues with our Whirlpool energy efficient water heater. Light would flash 5 times indicating bottom element was out. Replaced it two weeks ago and the light continued to flash and a constant clicking sound coming from the control box. This clicking has been on going for over a year.
Located the paperwork where we purchase the water heater and called their phone number for assistance.
Could not have been a more pleasant experience. The lady was very helpful and said we had never activated our lifetime warranty so she would enter it now for us. Then she said from what we told her it was the control module that was out and was fairly common problem. A new control board would be mailed over night to us at no cost. She even gave a brief but informative explanation of how to disconnect the old board and install the new one.
The part arrived the following day at 1130 a.m. We followed the steps and had in installed in 30 minutes or less. Been 3 days now and it has resolved the problem completely....very happy with Whirlpool and the manner in which the problem was addressed.
CassyD is offline   Reply With Quote
Old 08-20-2015, 08:24 AM   #44
Rewards Points: 2
Lifetime Warranty on Control Panel Not True
The first post in this thread regarding all control panels being given a lifetime warranty is not true. Our water heater is going through periods of extremely hot water and then periods of not hot enough water. Our neighbor is a plumber and said it is more than likely the control panel. The control panel was replaced the first year we moved in to our home and the water heater was new. I called Whirlpool and was told our water heater has a 9 year warranty and the control is not under warranty any longer. I mentioned what I read on this thread and they said they have never heard of this. Only water heaters with a lifetime warranty will have a lifetime warranty on the control panel. Beware! They are not covering the control panels on all water heaters unless there is a lifetime warranty.
krmnelson is offline   Reply With Quote
Old 10-18-2016, 09:42 AM   #45
Rewards Points: 2
Re: Whirlpool Energy Saver Water Heater Problem
Wow, scary stuff here. I noticed a smell of burning insulation in my house that I finally tracked down to this electric water heater and specifically to the control box located on top of the unit. There is a definite 'hot spot' when I place my hand on it. I called the number posted here and spoke with an American named Jesse, who was very helpful and after giving him my model and serial numbers, he wrote up an order and said he would have the part to me tomorrow, at no charge. I guess lawsuits and consumer complaints got their attention. I was pleased and should have my hot water back by tomorrow! If this should happen to you or someone you know, turn off the power to the unit until it is fixed! Good Luck!
hankdewald is offline   Reply With Quote
???A.O.Smith Water heater problem??? wrennels Plumbing 1 10-19-2009 07:57 PM
water heater problem ssikguitar Plumbing 3 09-01-2009 09:22 AM
Water Heater Troubles deadguydrew Plumbing 9 10-19-2008 09:30 AM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 03:32 AM
