Where Would Timer Be Located? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 05:08 PM   #1
where would timer be located?
I just changed the bulb in our outdoor post light for the first time. It must be on a timer, though - it goes on around 4 each afternoon and is off when we get up in the morning. We've never changed it since we've been in the house (3 years), and I can't find it - any clue as to where the timer might be located?
kkbri2008 is offline   Reply With Quote
Old 10-23-2008, 05:35 PM   #2
DIY'r
ScottR's Avatar
Basement or garage wall closest to the lamp, maybe?
It may look something like this..
Couldn't find an image with the cover closed.. gray or beige box, anways.
ScottR is offline   Reply With Quote
Old 10-23-2008, 05:39 PM   #3
Ok
so definitely inside? I'll have to look harder - that's what I thought too, but I didn't see anything when I looked a few months ago....the guy who lived in this house was a little strange, so it could be anywhere!! Thanks
Old 10-23-2008, 05:44 PM   #4
DIY'r
ScottR's Avatar
Well, I wouldn't say definitely inside..
I mean, technically speaking it could be in the attic or in a closet on the opposite side of the house or weirdly integrated into the lamp pole.. but I'm figuring that they probably used the least amount of wire to get from the panel to the timer to the lamp. So somewhere between the panel and the light, as the crow flies, give or take a few feet in all directions.
(And it may not look like that pic.. again, just guessing here..)
Old 10-23-2008, 05:45 PM   #5
the Musigician
DangerMouse's Avatar
"around" 4? or exactly 4? if it's not the same time, it's a sunsensor. that's what we have. on at dusk/off at dawn.
DM
Old 10-23-2008, 05:48 PM   #6
DIY'r
ScottR's Avatar
Now that is a question I wish I'd thought of..
Old 10-23-2008, 06:24 PM   #7
Rewards Points: 506
Send a message via AIM to theatretch85
DM
Exactly what I was thinking when I was reading through the posts here! I'd check out the light post wiring, remove the top and see what you have in the post for wiring. Iv'e seen the photo eyes in the inside of the post just barely sticking out, sometimes they are in the top of the light cage. Could also check the wire coming into the pole for power before the light "comes on" for the night; if there is power and the light is off then its a photo eye.
theatretch85 is offline   Reply With Quote
Old 10-23-2008, 10:16 PM   #8
Cow
Is it a dusk-to-dawn light(barn light)? They use a twistlock style photocell mounted on top of the light.
Cow is offline   Reply With Quote
Timer switch...any ideas how it works? mcvane Electrical 5 09-28-2008 06:32 AM
Timer Installation lpmike82 Electrical 3 06-21-2008 02:58 PM
dryer timer auto cycles don't work mikedudl Appliances 6 04-29-2008 07:48 PM
Porch lights with timer or photocell? ciera Electrical 4 10-29-2007 07:35 AM
Adding a timer to my outdoor house lighting ConstantChange Electrical 2 03-31-2007 08:56 AM
